Just going by the spec (3S 5200 mAh 50C), not looked at the link and know nothing about the make, yes more than powerful enough as long as it fits in your box, you may need to swap the connector.
All similar batteries should work if you set proper values in the battery settings menu. If you have never replaced that before - first check the connectors that yours battery has, and visually compare with the one that you plan to buy (cause sometimes connectors are different)...
