Doyle4 Posted December 29, 2017 Report Share Posted December 29, 2017 Had a look around and cant find one, cool if someone could point me in right direction? Needing some guidance on how to setup Device Monitor on device. Thanks! Link to comment Share on other sites More sharing options...
VapingBad Posted December 30, 2017 Report Share Posted December 30, 2017 I have not seen one, probably best to find a theme that implements the feature you want and examine it in Theme Designer. Link to comment Share on other sites More sharing options...
niandra3 Posted May 13, 2018 Report Share Posted May 13, 2018 @Doyle4 I'm a little late, but DJLSB put together the best guide I have found. Doesn't cover everything, but gets you started: Also, as it's been mentioned, just grab a theme with the feature you want and reverse-engineer it. 1 Link to comment Share on other sites More sharing options...
TonyB Posted May 23, 2018 Report Share Posted May 23, 2018 It would have been nice of Evolv if they had actually given us a guide to creating themes that work as we want them to with an explanation of what all the different settings do (as many sound or look similar but function differently) instead of leaving us to reverse engineer or fumble/guess our way through the settings in order to achieve what we want. HOW ABOUT IT EVOLV ? - I don't know if it exists but it would have been a great help instead of me spending a great deal of time tweaking settings to get this right. Link to comment Share on other sites More sharing options...
niandra3 Posted May 23, 2018 Report Share Posted May 23, 2018 (edited) On 5/23/2018 at 7:36 AM, TonyB said: It would have been nice of Evolv if they had actually given us a guide to creating themes that work as we want them to with an explanation of what all the different settings do (as many sound or look similar but function differently) instead of leaving us to reverse engineer or fumble/guess our way through the settings in order to achieve what we want. HOW ABOUT IT EVOLV ? - I don't know if it exists but it would have been a great help instead of me spending a great deal of time tweaking settings to get this right. Expand I keep asking them but they don't seem to have the time. They barely have documentation for EScribe, much less the theme designer. The video above is the best we've got so far. As I said above, I recommend finding a good theme and reverse-engineering it. The only tricky parts are the conditionals and hidden objects, everything else is pretty straightforward. Oh and you need some graphic design skills if you want to make your own icons and such. But yeah I agree.. it's a mess. And the UI isn't very well designed either so even with docs it would be somewhat confusing. Edited May 23, 2018 by niandra3 Link to comment Share on other sites More sharing options...
