tami Posted December 17, 2017 Report Share Posted December 17, 2017 Is it normal that my ohms are changing when I use it in power ctrl watts mode set my temp to off. Sometimes it reads 0.14 when I use it it changes to .013 or 0.15 or 0.16 is this normal for a dna250 paranormal 166? Please explain. Thanks Link to comment Share on other sites More sharing options...
retird Posted December 17, 2017 Report Share Posted December 17, 2017 Yep.... ohm's will change due to heating or cooling of the coil while vaping... Link to comment Share on other sites More sharing options...
tami Posted December 17, 2017 Author Report Share Posted December 17, 2017 7 minutes ago, retird said: Yep.... ohm's will change due to heating or cooling of the coil while vaping... I am new in DNA chip so you mean it's not like the normal chip that if it detects 0.14 it does not change unlike the DNA that automatically change depends on the temp of a coil? Thanks mate! Link to comment Share on other sites More sharing options...
iAlexander Posted December 17, 2017 Report Share Posted December 17, 2017 (edited) What material do you use? Even Kantal changes its resistance with temperature change, and DNA shows the real resistance all the time. By the way, there are multiple values that can be displayed on screen, change it to smth else that won’t disturb you… Edited December 17, 2017 by iAlexander Link to comment Share on other sites More sharing options...
retird Posted December 17, 2017 Report Share Posted December 17, 2017 The resistance of any coil will change when heated or cooled. It is not static. You can see this using Device Monitor by checking the box for cold ohms and the one for live ohms. As you vape you will see the live ohms change due to the coil (wire). being heated. Here is a screenshot showing this.... it shows cold ohms and the live ohms (while vaping) and you can see the resistance change. Link to comment Share on other sites More sharing options...
tami Posted December 17, 2017 Author Report Share Posted December 17, 2017 4 minutes ago, iAlexander said: What material do you use? Even Kantal changes its resistance with temperature change, and DNA shows the real resistance all the time. By the way, there are multiple values that can be displayed on screen, change it to smth else that won’t disturb you… I'm using fused clapton I think it's kanthal or what. Btw what is smth? Link to comment Share on other sites More sharing options...
tami Posted December 17, 2017 Author Report Share Posted December 17, 2017 2 minutes ago, retird said: The resistance of any coil will change when heated or cooled. It is not static. You can see this using Device Monitor by checking the box for cold ohms and the one for live ohms. As you vape you will see the live ohms change due to the coil (wire). being heated. Here is a screenshot showing this.... it shows cold ohms and the live ohms (while vaping) and you can see the resistance change. Yes I'm kinda confused for this is my first time using DNA250 chip. In my voopoo drag when I vape it does not change resistance unlike my paranormal 166. Btw thanks Link to comment Share on other sites More sharing options...
iAlexander Posted December 17, 2017 Report Share Posted December 17, 2017 (edited) I guess that your coil has kantal in the middle and SS or Nichrome wire over it... if resistance changes are around 0.01 - that’s ok. “smth” = something Edited December 17, 2017 by iAlexander Link to comment Share on other sites More sharing options...
tami Posted December 17, 2017 Author Report Share Posted December 17, 2017 1 minute ago, iAlexander said: I guess that your coil has kantal in the middle and SS or Nichrome wire over it... if resistance changes are around 0.01 - that’s ok. “smth” = something Lol sorry for that "smth" thought it was a profile or what. Btw thanks mate! 1 Link to comment Share on other sites More sharing options...
iAlexander Posted December 18, 2017 Report Share Posted December 18, 2017 For example, my current coil resistance changes between 1.49 and 1.54... Link to comment Share on other sites More sharing options...
