I’m using 26ga ss316l for a month and using it in TC mode as it supposed to and I get aroun 0,26 with 7wraps(dual). If I use the wire in the image, will it be safe and does ohm matter in TC mode? Thanks in advance.
P.S.: More wraps than 8 doesn’t fit my atomizer and I assume as fused claptons more than 6 will be too big for it. I own a Pilgrim GTA.
Also, I did a little research and it does support 0,08ohm+
Edited by PavorNocturnus
In actual device settings you use the wattage is important in TC ..... too low of a wattage setting and preheat is effected and the set temperature may not be reached....
Do you have any idea How many wattage I should use?
Set the wattage high enough to be able to reach the temperature setting you have set.  You can monitor, while firing, using Device Monitor.  It can show temp, watts, preheat operation, and etc. etc.  Then adjust to your needs, wants, and desires.... each person may want a different experience.... some want more preheat, some less,,,, some want quicker response, some don't...  just play with settings, pre-heat, punch, duration, temp settings, wattage settings, and etc. until you get the vape you want....
  • Like 2
