ozy41 Posted September 18, 2017 Report Posted September 18, 2017 (edited) Hello Guys, i have problems with my new device ... Escribe software see my Device but i can't turn it on anymore .... Only black screen on my Device ... the Batterys are new and married VTC6 have anybody a idea ... It´s a "Think Vape 167 DNA 250 Edited September 18, 2017 by ozy41
retird Posted September 18, 2017 Report Posted September 18, 2017 Is it in Stealth mode? Connect your device to EScribe, open Device Monitor, and what does it say at the very bottom of the Device Monitor screen where it says "Mode"? Have you changed any settings since you got your new device? 1
ozy41 Posted September 18, 2017 Author Report Posted September 18, 2017 (edited) vor 2 Stunden schrieb retird: Is it in Stealth mode? Connect your device to EScribe, open Device Monitor, and what does it say at the very bottom of the Device Monitor screen where it says "Mode"? Have you changed any settings since you got your new device? Last Night when i try some options about eScribe, it was everything perfect ill put my battery out ... but today in the morning when replace my battery the device stay off ... after then i plugged in eScribe detect my device but the display stay still off ... i don't really know whats the problem is but slowly iam really suffering. Edited September 18, 2017 by ozy41
retird Posted September 18, 2017 Report Posted September 18, 2017 From the screenshot you posted you are not getting the full voltage from both batteries and very low voltage from one thus your device won't charge and will not work without proper voltage.. With it plugged into EScribe it should be charging but it is not according to your screenshot. This issue could be caused by many things. Since it is new and still in warranty you might contact your vendor for replacement / repair. You could also start a ticket with Evolv. 1
Wayneo Posted September 18, 2017 Report Posted September 18, 2017 Have you tried another set of batteries in it, or verified those voltages on a charger? What kind of batteries? Like @retird mentioned, Cell 1 is only .57V, Cell 2 @ 2.27V. For most 18650's, the manufacturer has a 2.5V value for a completely discharged battery. Once it hit's 2V bad things start to happen internally (battery), so if those numbers are correct, those batteries are toast. 1
ozy41 Posted September 18, 2017 Author Report Posted September 18, 2017 Yeah i did, i have Vaper shop i have many solutions about batterys new cells but nothing helps... i use now for the test a Minkin v2 it function verry well with same cells ...
Wayneo Posted September 18, 2017 Report Posted September 18, 2017 I'd say @retird gave you solid advice 7 hours ago, retird said: ....... This issue could be caused by many things. Since it is new and still in warranty you might contact your vendor for replacement / repair.
