exisius Posted September 14, 2017 Report Share Posted September 14, 2017 I want to place my ohms where my current battery meter is and put battery 1 where the amps are at the bottom of the screen and battery 2 where the volts are in the middle and battery 3 where the ohms are currently. Can someone help me with this on my think vape finder 250 this is the only screen I want to do anything with. Thank you in advance. Link to comment Share on other sites More sharing options...
Wayneo Posted September 14, 2017 Report Share Posted September 14, 2017 Escribe Screen tab. Very easy and possible to do. 4 device states to choose from (regular while in use OR just charging) and (Temp sensing while in use or just charging). Remember to upload changes to the device after you make changes. Welcome! Enjoy your mod. Link to comment Share on other sites More sharing options...
giz_60 Posted September 14, 2017 Report Share Posted September 14, 2017 27 minutes ago, exisius said: I want to place my ohms where my current battery meter is and put battery 1 where the amps are at the bottom of the screen and battery 2 where the volts are in the middle and battery 3 where the ohms are currently. Can someone help me with this on my think vape finder 250 this is the only screen I want to do anything with. Thank you in advance. The battery meter itself can not be changed...you can only change/customize the other 3 fields on the screen.... Link to comment Share on other sites More sharing options...
exisius Posted September 14, 2017 Author Report Share Posted September 14, 2017 1 minute ago, giz_60 said: The battery meter itself can not be changed...you can only change/customize the other 3 fields on the screen.... Then in that case is the batery feild showing only 1 batteries level or is it showing the total power left from all 3 batteries, because if its only showing the power from 1 battery then i can work with that and if that is the case then which battery is it showing? Link to comment Share on other sites More sharing options...
giz_60 Posted September 14, 2017 Report Share Posted September 14, 2017 (edited) The battery indicator is showing the collective level... Edited September 14, 2017 by giz_60 edit Link to comment Share on other sites More sharing options...
