akistriantas Posted August 31, 2017 Report Posted August 31, 2017 Hello friends before 5 days I bought my first dna device a vapecige sd 75c. Today i build a ss316l coil to test the temperature control I measure the resistance(0.55Ω) and after I lock it in room temperature but then when it goes to sleeping mode and I unlock it to vape the resistance is unlocked. When I press the fire the resistance ohms doesnt change but the icon of lock shows it unlocked. Why this happened? 1
VapingBad Posted September 1, 2017 Report Posted September 1, 2017 I would check what it says when connected to EScribe to be sure as it could be a bug in the theme.
akistriantas Posted September 1, 2017 Author Report Posted September 1, 2017 Thnks for the reply my friend.So I check it through escribe, so when the device was locked I connect it and I download the settings I go to the profile of ss and I see the resistance unlocked, I unlock the device and download the settings again and still the resistance was unlocked.Now I lock the resistance through escribe and Im waiting to see what happened the next thing to do is to change theme and see.....
akistriantas Posted September 1, 2017 Author Report Posted September 1, 2017 ok now that I check to lock the resistance from escribe when I unlock the divice the resistance stay locked I check it for the whole day and after I ll change the theme to see what happened.
etab75 Posted September 1, 2017 Report Posted September 1, 2017 Can you upload the original Vapecige SD75C theme so we can take a look? I'm interested in adding one to my arsenal as a beater model - look fairly good for the price.
akistriantas Posted September 1, 2017 Author Report Posted September 1, 2017 I have change my theme and by mistake I dont save the default.....The price is more than good for this mod....
etab75 Posted September 1, 2017 Report Posted September 1, 2017 Ah well! Yep I've seen mixed feedback, but it looks solid for the low price and the chip is great so...
X-R4Y Posted October 16, 2017 Report Posted October 16, 2017 I´ve got the same issue on another VapeCige Creator device. After deep sleep and 5-click unlocking the resistance is unlocked. This happens on many different themes, so i think this is a overall bug and not theme-related?
James Posted October 16, 2017 Report Posted October 16, 2017 What firmware Service Pack are you running? By the way, EScribe automatically saves settings which would include your theme. Go to Help -> Backups. If you used Theme Installer, Theme Designer will have the backup (or the Backups button of Theme Installer).
James Posted October 17, 2017 Report Posted October 17, 2017 Good catch. It looks like altering it on the device (as opposed to via EScribe) doesn't trigger a save, unless the material or Ohms change. I'll have this fixed for SP8. 1
X-R4Y Posted October 17, 2017 Report Posted October 17, 2017 Okay, sounds good :-) It is a little bit annoying. Especially in TC mode
James Posted October 17, 2017 Report Posted October 17, 2017 You should still be able to lock it fine if you upload that from EScribe.
James Posted October 25, 2017 Report Posted October 25, 2017 Hello @X-R4Y. I've posted SP8 in "EARLY SERVICE PACK (all devices)" of the Early Firmware and EScribe Suite thread. It fixes the problem you are having with Ohm Lock.
X-R4Y Posted October 25, 2017 Report Posted October 25, 2017 I´ve uploaded it to my device. First test was successful :-)
