Tilt.84 Posted July 24, 2017 Report Share Posted July 24, 2017 Hi, i have received a billet box with the dna60 brand new from the shop. I installed a ssocc clapton coil 0,5ohm and vaped at 35watts. After the second tank, i reffiled it and just after few vapes the power went down to 8.5 watts, cliking the up button it appear the press up and down to lock the res, but i didnt need and want to block it and last it appears the chip code from evolve and from that point i cant do nothing. I changed battery, coil, but same thing happened. What it could be?? Im so sad about it!! Thanks for your help. Link to comment Share on other sites More sharing options...
67exec Posted July 24, 2017 Report Share Posted July 24, 2017 The controls are the same. Start at 15:20 Link to comment Share on other sites More sharing options...
Tilt.84 Posted July 24, 2017 Author Report Share Posted July 24, 2017 It is blocked. When i press to unlock it doesnt actually unlock. The fire button doesnt work anymore. Link to comment Share on other sites More sharing options...
retird Posted July 24, 2017 Report Share Posted July 24, 2017 Connect it to EScribe and run the Device Monitor.... take a screenshot of Device Monitor and post it here.... we need more information.... 1 Link to comment Share on other sites More sharing options...
67exec Posted July 24, 2017 Report Share Posted July 24, 2017 I agree with @retird. Also, I watched some teardown vids and it appears that bb uses off-board buttons so one may be bad. When in device monitor you should be able to simulate button presses, which would allow you to make escribe fire the mod. Link to comment Share on other sites More sharing options...
Tilt.84 Posted July 24, 2017 Author Report Share Posted July 24, 2017 It is on a Billet box no usb port. But when it appears the evolv code product with few numbers i ll guess that is not a good sign. Because i vaped with it, and then the power went down by it self and i cant do much if it looks like i cant unlock the res Link to comment Share on other sites More sharing options...
67exec Posted July 24, 2017 Report Share Posted July 24, 2017 Shows how to change button, but also shows the stock evolv fire switch is still on the board, that would let you do some troubleshooting even w/o escribe 1 Link to comment Share on other sites More sharing options...
retird Posted July 24, 2017 Report Share Posted July 24, 2017 Take it back to the shop you got it from if you can't access EScribe via USB port..... No USB port? Why no USB port... Link to comment Share on other sites More sharing options...
67exec Posted July 24, 2017 Report Share Posted July 24, 2017 Billet box apparently didn't think it was necessary. There are several yt vids showing how to add usb to it though. Link to comment Share on other sites More sharing options...
Tilt.84 Posted July 25, 2017 Author Report Share Posted July 25, 2017 So i must use escribe to check what is wrong with it?? I ll go and check the trobleshooting thread to understand what o could do with it. Link to comment Share on other sites More sharing options...
Tilt.84 Posted July 25, 2017 Author Report Share Posted July 25, 2017 19 ore fa, 67exec ha scritto: Billet box apparently didn't think it was necessary. There are several yt vids showing how to add usb to it though. Yes i saw the video about it. But evolv help desk said that probably it is the down button that is stucked so i need to open it and see what is going on. Link to comment Share on other sites More sharing options...
bigpeat59 Posted November 4, 2017 Report Share Posted November 4, 2017 Le 25/07/2017 à 00:32, Tilt.84 a dit : Hi, i have received a billet box with the dna60 brand new from the shop. I installed a ssocc clapton coil 0,5ohm and vaped at 35watts. After the second tank, i reffiled it and just after few vapes the power went down to 8.5 watts, cliking the up button it appear the press up and down to lock the res, but i didnt need and want to block it and last it appears the chip code from evolve and from that point i cant do nothing. I changed battery, coil, but same thing happened. What it could be?? Im so sad about it!! Thanks for your help. Hello, I have the same problem. Have you solved it ? Link to comment Share on other sites More sharing options...
retird Posted November 4, 2017 Report Share Posted November 4, 2017 Here is the datasheet for the DNA 60 should anybody not have seen it......lots of info here : https://downloads.evolvapor.com/dna60.pdf Link to comment Share on other sites More sharing options...
delfino40 Posted June 20, 2019 Report Share Posted June 20, 2019 hi, i have a modeur mod with dna 60 with no usb pot and i have the same problem... someone have a solution please? Link to comment Share on other sites More sharing options...
