shamus20 Posted July 14, 2017 Report Posted July 14, 2017 so about a week ago my lipo started charging properly on my DNA 200 board, now i know that i have had this for awhile (just over 1 year) but it went from charging 1amp to .31 and .019 when plugged into the wall and my computer. i did get 100% charge on an RC car charger but the dna no longer charges to 100% unless i wait about a day for it to finish (took 8 hours to get to 30%.) the lipo pack is not expanding and it is rated at 2200mah at 50c so it should not be a battery issue (no expansion on the pack either.) i have tried soft and hard reset and even a firmware install from escribe, setting up the battery profile and everything. if there is any advice that you may be able to give i would greatly appreciate it.
VapingBad Posted July 16, 2017 Report Posted July 16, 2017 I would check that each cell is charging evenly, look at the cell voltages in EScribe or put them as the optional fields on the charge screen. It sounds like it is spending a lot of time balance charging, also worth checking the white JST balance connector is clean and tight. 2
