What do you guys think?
Minimum Capacity:
5000mAh
Configuration: 3S1P / 11.1v / 3Cell
Constant Discharge: 25C
Peak Discharge (10sec): 30C
Pack Weight: 412g
Pack Size: 146 x 50 x 25mm
Charge Plug: JST-XH
Discharge plug: 4mm Bullet-connector
Capacity(mAh)5000
Config (s)3
Discharge (c)25
Weight (g)412
Max Charge Rate (C)2
Length-A(mm)146
Height-B(mm)50
Width-C(mm)25
Yes if you like huge mods.
People in general specifying high mAh remember the bigger the battery the longer it takes to charge, personally I have a low tolerance for anything that takes over 90 mins to charge test days. I think it is life style specific if you spend most of the day close to a USB socket you can keep topping up, but if not and you have a 3 day battery it is going to need a long charge time, we are all different and YMMV.
That's also going to be quite a long device,
The higher mah batteries I have looked at in the Uk (Turnigy nano tech from HobbyKing)
all seem to be rather long
HUGE MOD, I think you'll be surprised at the life of a 1000 Mah lipo, Remember what mamu said about it using individual cells. So that the mah is almost tripled.:)
If you bother to read I said huge mod about a 5000 mAh battery.
I've been thinking about using these for my enclosures. I think with the varied experience levels involving LiPo's of potential users, having a reliable battery is paramount in building a successful mod. The footprint of this one below seems to be the best I can find considering it being 1850mAh.
http://www.maxamps.com/proddetail.php?prod=Lipo-1850-111-Pack
Definitely is pricey but for the mod I'm working with an architect to design, the price point should offset the cost for building, at least in my case.
