Jcca1973 Posted August 1, 2015 Author Report Posted August 1, 2015 Mine have stop working after 2 days
KTMRider Posted August 1, 2015 Report Posted August 1, 2015 The one I build has been working great for 9 days now. My Hana lasted about 24 hrs before the screen died but it's still working.
mattman75 Posted August 2, 2015 Report Posted August 2, 2015 My first one died after a week. Emailed Evolv and waiting on response.
KTMRider Posted August 2, 2015 Report Posted August 2, 2015 Ok, my first statement wasn't completely true. My built box had a pinched display ribbon and the dispaly was cutting out when I touched the fire button, not just firing. I replaced the display, pre-bending the ribbon cable so it collapses on itself and away from the fire button. It was hardwired because my XT30 connectors were delayed and I was impatient. I got my connectors Friday and installed them so now it's perfect and haven't had any issues. I was vaping on my Hana yesterday even with the screen blank. I might try to replace the screen later today.
John Posted August 2, 2015 Report Posted August 2, 2015 Yes, this is an excellent thread. If you could also post symptom ms, firmware, how long it went before the symptoms showed up and (if you can) the original programming date. That would be most helpful.
Darklyspectre Posted August 2, 2015 Report Posted August 2, 2015 Died after about 6 hours of usage. Fuse burned out for some reason. sending it in when I get a reply from evolv's warranty request.
John Posted August 2, 2015 Report Posted August 2, 2015 How many of these most recent early mortalities were during active use, versus on wake from sleep (not being used or charged for over an hour)?
blueridgedog Posted August 2, 2015 Report Posted August 2, 2015 I have not had a dead board. I have gone through some screens as I have been doing mod design work for others, so a lot of install and removal. The screen's are fragile. I just finished a small screen DNA40 layout and the chip/screen made it through four test prints (very tight fit) before giving up. At least I don't have to be gentle with number five!
Darklyspectre Posted August 2, 2015 Report Posted August 2, 2015 John said:How many of these most recent early mortalities were during active use, versus on wake from sleep (not being used or charged for over an hour)?Mine was during unlocking the device after 10 minutes of not being used. screen showed the 5 pressed to unlock. and while unlocking it it just died. so mine wasn't during active(as in vaping) use.
steamer861 Posted August 3, 2015 Report Posted August 3, 2015 I had one malfunction yesterday. I built this one a little over a week ago.It is in a 3D printed box and use's a Gens Ace 1300mAH battery.From what I'v read it has a burnt fuse and possibly some other issue that caused it.This particular board was doing some thing a little odd, every once and a while it would power way up and the hit off it would be so hot I could barely stand it.Nothing would change in escribe or on screen but the vape was different .Then as mysteriously as it came it would go and the board would seem fine.Then yesterday during one of it's mystery power up episodes it stopped working.Rite as I was taking a really hot hit.At first I connected it to the USB and opened escribe and nothing it was dead.So upon further inspection it appeared that the fuse had blown.I did a bit of reading and read that if the fuse was blown that escribe would still recognize the board.I reattached to the USB and open escribe the screen came on but escribe would not recognize it, it had no battery attached at this point.I connected the battery back to the mod and plugged it back into the usb, openedescribe and the screen came on the board was recognized by escribe.I was able to connect and down load settings.At first it pop up an error saying eprom could not be read. But on a second attempt the error went away.Everything seemed normal at this point, so I tried to attach an atty while it was still connected to the USB and it would go dead rite away, also as soon as I disconnected the USB it would go dead to.Here's a Pic of the fuse it.s a little hard to tell from the pic but the top is blown rite offSo now I put in an inquire at the Evolv site and am waiting for a reply.FYI the one that blew the fuse was running a dual coil TI build at .1I was using a custom CSV file from Steam engine site.I have another mod exactly the same I put together just a few days ago.It is working perfectly for 3 day now running dual NI 200 coils at .08 Here' a pic of the good one
sgtmonty Posted August 3, 2015 Report Posted August 3, 2015 I had one die after a few minutes of non use. Was great for a couple days then just nothing. Fuse was still intact but it does nothing not even when connected to pc
Always_Jonezen Posted August 3, 2015 Report Posted August 3, 2015 I had one arrived DOA, only powers on though eScribe still waiting on a response to send it in. Hopefully they can fix or replace it since I'm stuck using this sx350j chip
