Please Help! DNA dead and get`s hot if connected to USB.
D022A
After two weeks of "Vapors heaven" my DNA 200 just stopped working in the middle of a puff...
Due to the size of my mod I had to solder the battery wires directly to the board, so I can't try to kind of "restart" the DNA.
I checked all wires, connections and the fuse and everything looks absolutely fine.
If I try to connect it to the PC nothing happens, display stays black and doesn't connect to Escripe.
BUT: If connected to USB, the board (the two big squares on the board) are getting very hot.
Firmware *** 2015-08-07 EScribe ***
Already tried to rerun a firmware update but it can't connect.
I was running a 0.04 dual Nickel clapton.
Using a nano tech 950mah
First of all, thanks for your reply blueridgedog.
I disassembled the hole mod and removed the battery wires.
Without battery the DNA should connect and show up in Escripe but it's still dead.
I noticed something while plugging the USB cable in and out.
As soon I plug in the USB cable, I can hear some "clicking" sounds coming from the USB port location of the board. I can't see any burn marks or possibly shorts.
As you probably already noticed I'm not from the USA so it's hard for me to describe... Sorry for my bad English.
As I live in Germany I don't know how or even if a return could probably work.
Looks like I need to order a new one from Ireland.
Sorry Josh... I'm German and we are known for exports ;)
Help desk helped me a lot so just open a ticked.
@James: I was running the *** 2015-08-07 EScribe *** Firmware. And I was using a 3D printed reference design from shapeways.
I will PM you the SN.
