Danielson Posted October 9, 2015 Author Report Posted October 9, 2015 New to Dna chips my vt 200 never asks if it's a new coil when I change why is that ? And in temp mode I'll have it set to a wattage and it will never get to it even if I have it at like 50 watts and 500 degrees do you have to make a tcr curve for every coil? And is it better to lock ohms or not because I've seen quite a few posts saying don't lock them? Just using ni200 for now
retird Posted October 9, 2015 Report Posted October 9, 2015 If you are not in temp mode it never asks if it is a new coil as you are vaping in power mode (wattage). In temp mode you only get enough wattage to reach and maintain the temp setting thus a 50 watt setting may not be needed. Example: I vape at 400F @ 24 watts with a nickel coil. It briefly hits 40-ish watts (during preheat) and immediately drops to 20-ish watts and then 13 watts and lower after reaching temp. It only uses the wattage needed to maintain temp.Some folks lock ohms and others don't I never use ohm lock as I want the device to "refine" along the way.
VapingBad Posted October 9, 2015 Report Posted October 9, 2015 It only asks new/same coil if the resistance is within 25% of the last coil (this can be changed in Escribe)You only need to make a TCR for wire other than Ni200 or KanthalI almost never lock ohms, if you lock them then the DNA can not refine them for greatest accuracy.
travanx Posted October 9, 2015 Report Posted October 9, 2015 Locking ohms for stainless steel makes a huge difference.Make a profile for each coil so you don't have to change settings from the mod itself.
Danielson Posted October 9, 2015 Author Report Posted October 9, 2015 Ok thank you now with the coil I have in now I had the ohms locked and it was reading.05 got of work took two hits and its reading.09 and when I take a hit its reading kanthal max power and its in temp mode on a magma 24 gauge ni200 10 wraps spaced
Freshcut Posted October 9, 2015 Report Posted October 9, 2015 Hi guys, im new to DNA. Just got a VT200. May i know how does adjusting preheat value in escribe works?
