labo Posted October 18, 2015 Author Report Posted October 18, 2015 Hi everybody, I have a VT200, I updated it with the latest firmware 30/09/2015Left info (ohm, volt, temperature) doesn't change when I put it under charge with USB cable.If I change default fields in non charging mode every field works as expected but they don't change, regardless it is USB connected or not.The problem was still present with older firmwares.I tried different USB cables and wall chargers.
awsum140 Posted October 18, 2015 Report Posted October 18, 2015 I'm not trying to be a wise guy, but you do realize that the standard screen has to time out and you need to increase the charging screen brigtness using Escribe to be able to see the display during charging. I fell into that same trap, LOL.
retird Posted October 18, 2015 Report Posted October 18, 2015 Basic question. Are you uploading your changes to the device after you make them in EScribe?
labo Posted October 18, 2015 Author Report Posted October 18, 2015 awsum140 said:I'm not trying to be a wise guy, but you do realize that the standard screen has to time out and you need to increase the charging screen brigtness using Escribe to be able to see the display during charging. I fell into that same trap, LOL.That was the problem, thanks man, however it's not explained very well in the software
awsum140 Posted October 18, 2015 Report Posted October 18, 2015 Yeah, kind of a built-in "gotcha". Sometimes I think there's too many variables that can be set in the software, but then if there weren't it wouldn't be a good. Kind of a conundrum.
