Xx3dge Posted October 17, 2015 Author Report Share Posted October 17, 2015 Is it normal that my room temp is 8°f higher then my actual thermometer I have in my room? I'm going by the live readings on escribe. Link to comment Share on other sites More sharing options...
mikepetro Posted October 17, 2015 Report Share Posted October 17, 2015 I am interested in the response to this. I have 10 degrees higher even after running case analyzer. Link to comment Share on other sites More sharing options...
VapingBad Posted October 17, 2015 Report Share Posted October 17, 2015 And me, ran case analyser 3 times and still about 10 F high. Link to comment Share on other sites More sharing options...
scoopy Posted October 18, 2015 Report Share Posted October 18, 2015 Interesting. .. After running case analyser twice on my mod I'm getting like 6-8 degrees lower than actual room temp Link to comment Share on other sites More sharing options...
dwcraig1 Posted October 18, 2015 Report Share Posted October 18, 2015 Mine has been sitting for a couple of hours unused with no usb attached, read the thermometer on wall near it, mod says 87.25F and thermometer reads 88.Thermometer is about 3 feet higher. I'll check it again after it's been connected with usb for a whileand see if there's a difference.And a little later with usb plugged in and charging, board room temp is 93F, thermometer says 90F Link to comment Share on other sites More sharing options...
retird Posted October 18, 2015 Report Share Posted October 18, 2015 Reference mod sat overnight to reach room temp. Started EScribe, plugged in reference mod (holding mod by the tank so as not to raise the device enclosure temp). Immediately clicked Device Monitor and read room temp. Digital Room Thermometer setting next to reference mod read 69.70 F and Device Monitor showed room temp. at 69.52 F. Link to comment Share on other sites More sharing options...
Xx3dge Posted October 18, 2015 Author Report Share Posted October 18, 2015 So should I run the case analysis when the device has been sitting overnight? Is the values I'm using wrong since I was handling the device before starting case analyzer? Link to comment Share on other sites More sharing options...
