the current board evolv sells to the public will not support 2 amp charging. vaporshark asked evolv to make them a special board. vaporsharks dna pcb is slightly longer and it has to be to accomodate the extra components for 2 amp charging. no firmware upgrade will allow the current version of the board to do so. but maybe in the future evolv might sell the dna with 2 amp charging. look for a topic in general discussion i posted about how vaporshark has 2 amp charging. that will explain more.
https://forum.evolvapor.com/topic/66857-topic/?do=findComment&comment=901462
skineedog said:
Implementation of an option to charge at 2 amps instead of 1? Seems like it should be possible with firmware? 1 amp is pretty fast but faster is better, right?
If you commit to buying 500,000 DNA 200 boards they may sort you out ;)
