Margucci Posted October 31, 2015 Report Share Posted October 31, 2015 for the battery capacity you want to set it to 9.99 Wh. the cell soft cutoff is 3.09V. after you have that set run the battery analyzer and case analyzer. just follow the directions that are shown. the one field which is under debate is the mod resistance. at one place volcano is saying it should be set to 0.02. in another they have said 0.007 (which is in line with the vaporshark). some people have tested it themselves at 0.02 and others have tested it themselves at 0.007. there are a few ways you can test your own mod (do any of these tests with the mod resistance set to 0):1- have a threaded brass or copper pin which you short out the 510 connection with2- have a non threaded brass or copper pin which fit in the 510 as snugly as possible and shorts the device3- use an ohmmeter to measure the resistance of a build and compare that to what the DNA200 is reading. the difference is your mod resistance. 4- get a RDA deck (dual coil at least ideally) and short the posts with the thickest copper wire you can fit in the holes. the resistance you read is your mod resistance. without a doubt #1 will give you the best result. depending on the overall fit of #2 will influence that methods reliability. #3 will increase in accuracy the better the ohmmeter you use. a high quality multimeter or oscilloscope will give you the best readings. #4 will be measuring the resistance of the deck as well as the mod resistance so there is more uncertainty. in any case i would not ever recommend setting the value to anything over 0.02 as this is quite high to begin with and immediately caused a knee jerk reaction when we first saw it. personally if you dont want to or arent able to test yourself a fairly safe value is 0.007 which is around what most DNA200 devices have their internal resistance set to. Link to comment Share on other sites More sharing options...
jjmlman Posted October 31, 2015 Report Share Posted October 31, 2015 So if i set my mod resistance to 0.007 the battery wh at 9.99 and the cell soft cutoff to 3.06 i will be good to go and most off safe correct Link to comment Share on other sites More sharing options...
Margucci Posted October 31, 2015 Report Share Posted October 31, 2015 run the two analyzers as well. the battery analyzer will give you your discharge profile and the case analyzer will recording the effects of the case on the temperatures in the device. Link to comment Share on other sites More sharing options...
bmclaurin Posted October 31, 2015 Report Share Posted October 31, 2015 jjmlman said:So if i set my mod resistance to 0.007 the battery wh at 9.99 and the cell soft cutoff to 3.06 i will be good to go and most off safe correct Yes, put those numbers in there, and even if you never run any of the analyzers, it will be one of the best vapes you've ever had. Link to comment Share on other sites More sharing options...
xer0 Posted November 4, 2015 Report Share Posted November 4, 2015 I've noticed with my Lavabox running a Crown .25ss dual coil, its reading high ohms at .33, now when I screw this tank onto my MVP pro 3 it reads correct at .25ohms.Back on the Lavabox the vapour is very hot, i've just knocked it down to 44watts which seems very low for this coil and the vape is still pretty warm.Any suggestions? Link to comment Share on other sites More sharing options...
scoopy Posted November 4, 2015 Report Share Posted November 4, 2015 Did u change the mod resistance at all? What does your mod resistance say in the box? Link to comment Share on other sites More sharing options...
Margucci Posted November 4, 2015 Report Share Posted November 4, 2015 i would screw it on another couple of mods or ohmmeters to see what those spit out. it could be that your mod resistance is just huge. if everywhere you test it the lavabox is constantly reading high by the same amount (in this case 0.08, which is a lot), than take 80% of that value and use that as your mod resistance (assuming that it is currently set to 0). i do have to say that 0.08ohm would be huge for the mod resistance though. some people are reporting 0.02, which is still large compared to readings of 0.007-0.008 that others are seeing. this is why mod makers need to realize that the mod resistance is incredibly important and needs to be tested for EACH AND EVERY mod. a standardized value will not do. Link to comment Share on other sites More sharing options...
xer0 Posted November 4, 2015 Report Share Posted November 4, 2015 I set my mod resistance to 0.007. My kanger sub tank showing 0.56 on the mvp is also showing 0.61 on the lavabox :S Link to comment Share on other sites More sharing options...
AlohaBill Posted November 5, 2015 Report Share Posted November 5, 2015 Volcano just posted a downloadable csv file for the Lavabox.http://www.volcanoecigs.com/blog/evolv-escribe-use-with-the-lavabox-dna-200.html Link to comment Share on other sites More sharing options...
Margucci Posted November 5, 2015 Report Share Posted November 5, 2015 i dont trust that mod resistance in the slightest. it honestly feel like they just copied it from the vaporshark instead of testing it themselves. someone on here i believe is making some brass shorting pins which i would be very interested in purchasing (depending on the price and shipping). there have been quite a few people who have had quite a large swing in mod resistance on their DNA devices. for reliable TC it is 100% necessary for each mod to be tested individually. thanks a lot for the link though. i will see what they update in there. honestly though, im only interested in the mod resistance anyways. the only two other things (battery and case thermals) we can run the tests for easily on our own. Link to comment Share on other sites More sharing options...
Bluewall Posted November 5, 2015 Report Share Posted November 5, 2015 AlohaBill said:Volcano just posted a downloadable csv file for the Lavabox.http://www.volcanoecigs.com/blog/evolv-escribe-use-with-the-lavabox-dna-200.htmlThank so much for the head up ! Link to comment Share on other sites More sharing options...
Margucci Posted November 5, 2015 Report Share Posted November 5, 2015 so i had in interesting exchange with them over twitter. they tweeted that there was the ecig file for the DNA....Me: "what method did you use to determine the mod resistance of 0.007 ohm?"Them: "we had a little help from the folks at evolv"Me: "evolv cant help you with that. only testing your mod yourself with a short will."Them: "we obtained out testing method from evolv and came to our answer"..... so they did no testing at all and probably just copied it from vaporshark or the evolv reference model. what they needed to do was test a decent number of lavaboxes to determine the variance and then calculate an amount representative of the average while still being conservative enough to not cause issues with outliers. they did no work at all to set this device up correctly. none at all. its at least good that we are able to do their work for them using the escribe software. great work on the chip and software evolv. terrible implementation by volcano. Link to comment Share on other sites More sharing options...
bmclaurin Posted November 5, 2015 Report Share Posted November 5, 2015 ...and the 3.66v LVC that they recommend is silly.But, guys, on the mod resistance... If you have, say, a mech mod with a copper pin, you can use that to get a pretty good reading on your mod resistance. No doubt, a threaded copper plug would be better, but it will still get you pretty close. Just pull the pin out of your mech mod and insert it into the 510 connector. press it down with something non-conductive so it makes good contact with the positive and negative surfaces of your 510 connector. Move it around a little until you get a steady reading. That's all there is to it. Mine came in at 0.007 ohms as you can see in the pics below. Link to comment Share on other sites More sharing options...
Margucci Posted November 12, 2015 Report Share Posted November 12, 2015 we are aware of how to do this. the point is that when you are spending the amounts we are on mods (after all they arent $50 items on fasttech), these are the things which should have been done beforehand. Link to comment Share on other sites More sharing options...
