14ga vs 16ga 510
I used 12 gauge to the 510 connector, an FD version 4.  What I did was bring the wire in at right angles rather than straight in to the center pin.  I pulled out enough wire to filled the center hole and "fanned" the rest out around the pin.  After soldering, I trimmed the fan flush with the sides of the pin.  Took some time and fussing, but it worked out really well.  If you cn bring the wire in at right angles, it might work for you, either that or get a different, Evolv, 510 connector.
 Share
