jarred.sayles Posted March 1, 2016 Author Report Posted March 1, 2016 I got got my Black Griffin in today. I ordered some Titanium. What is the best AWG to use as well as how many wraps. etc.?
jarred.sayles Posted March 1, 2016 Author Report Posted March 1, 2016 All I know is Im ready to start to building to not only save money but to blow humongous clouds, and get that great flavor!
Spector NS5 RD Posted March 1, 2016 Report Posted March 1, 2016 jarred.sayles said: All I know is Im ready to start to building to not only save money but to blow humongous clouds, and get that great flavor! Expand i like 26 awg. not too thin not too thick. 8 slightly spaced wraps for a dual coil. 5-6 for single. titanium is my fave out of the bunch i have.
awsum140 Posted March 1, 2016 Report Posted March 1, 2016 I'll second Chunky on the titanium, nickel gives me a metallic flavor. I use 28 gauge and if I want it "heavier" I just twist some up. 7-8 wraps on a 3mm mandrel works fine for me in Aromamizers and Foggers.
kismetcapitan Posted March 2, 2016 Report Posted March 2, 2016 24 gauge Pt950/Ru (95% platinum/5% ruthenium). Titanium has a flavor too, but it's hard to detect until you vape on a wire that has absolutely no flavor at all, because it's chemically inert when used as a heating coil. It does not oxide with anything in the atmosphere at any reasonable temperatre You can dry fire it to blindingly hot - not just glowing, or red hot, but where it's getting to be as bright as a lightbulb filament - and all that happens is that every bit of gunk on the wire vaporizes and the coil is shiny and new. It will literally last forever. Because no oxide layer forms on the outside, the coils must be spaced.On my Griffin I built dual chimney coils. Nice clouds, and because the only air route is through the inside of the coil, the flavor is intense.
jarred.sayles Posted March 3, 2016 Author Report Posted March 3, 2016 kismetcapitan said: 24 gauge Pt950/Ru (95% platinum/5% ruthenium). Titanium has a flavor too, but it's hard to detect until you vape on a wire that has absolutely no flavor at all, because it's chemically inert when used as a heating coil. It does not oxide with anything in the atmosphere at any reasonable temperatre You can dry fire it to blindingly hot - not just glowing, or red hot, but where it's getting to be as bright as a lightbulb filament - and all that happens is that every bit of gunk on the wire vaporizes and the coil is shiny and new. It will literally last forever. Because no oxide layer forms on the outside, the coils must be spaced.On my Griffin I built dual chimney coils. Nice clouds, and because the only air route is through the inside of the coil, the flavor is intense. Expand Where can you find that type of wire and gauge? And how much is it?
Johan Posted March 3, 2016 Report Posted March 3, 2016 https://www.riogrande.com/Product/950-platinum-round-wire-dead-soft/699324
awsum140 Posted March 3, 2016 Report Posted March 3, 2016 What are you using for a TC on that wire, Johan? I see 3.93x10(-3) listed but don't see a listing for the ruthenium. I'm guessing the 3.93 number would work, but just want to ask. It is expensive, ~$50/ft, but if it can be dry burned, easily, that negates the added expense.
Spector NS5 RD Posted March 3, 2016 Report Posted March 3, 2016 it lists the description of the Pt's flexibility as 'dead soft'. why am i thinking this is softer or as soft as nickel? one of the main reasons i moved away from Ni, too soft. what about 10k-14k gold? not as soft as 24k (pure).
Johan Posted March 8, 2016 Report Posted March 8, 2016 I didn't get any, was thinking about it, still may. The number you posted is all I found also. Was hoping steamengine would have it with the new materials they added...Was just reading about platinum wire on a jewelry making site, apparently you can work harden it if it's too soft. One method they use is spinning it with a drill motor and holding other end with pliers just like you would to straighten core wires for clapton (coaxial) wire.And my apologies to the OP, kind of off on a tangent here for a question about starting to build your own coils
