Rustdust Posted March 1, 2016 Author Report Share Posted March 1, 2016 OK so I think I have made a really nice TFR/CSV file for the Crown SS Coils, everything else I have used or made has been to week or just hasn't really worked the way I felt it should on my DNA200 and I know its been an issue for many people. Try this in Steam Engine to create the csv file and let me what you think.24 gauge - SS 304 - parallel - 8 wraps and a inner coil dimension of 6 mm, I left the wrap spacing at 0.5 and the leg length at 5mm.I'm running this at around 260 degrees C with 60 watts cheers RustdustEdit: I forgot to mention that this was based on a 0.5 ohm crown coil that I dismantled and it would be reasonable to assume that the 0.25 ohm coil would be less wraps. Link to comment Share on other sites More sharing options...
TobyWong7 Posted March 2, 2016 Report Share Posted March 2, 2016 The wraps, diameter, and dual coil don't matter. The TFR/CSV is going to be the exact same using 304 stainless no matter what the guage is or how the coils are made as long as 304 stainless is the only material used Link to comment Share on other sites More sharing options...
Rustdust Posted March 2, 2016 Author Report Share Posted March 2, 2016 OK well I'm certainly no expert but what a difference its made Link to comment Share on other sites More sharing options...
Michael Hancock Posted March 2, 2016 Report Share Posted March 2, 2016 What does your graph look like with this in the analyzer? I've yet to see a nice clean straight temp line on SS. They always look like the Rockies. Post a screen shot if you can. Link to comment Share on other sites More sharing options...
Rustdust Posted March 3, 2016 Author Report Share Posted March 3, 2016 Link to comment Share on other sites More sharing options...
Michael Hancock Posted March 3, 2016 Report Share Posted March 3, 2016 Unfortunately yours is all over the place as well. SS is tough to get stable and the crown coils are much harder because of the Ni legs it has. Link to comment Share on other sites More sharing options...
NickyGiaccone Posted April 6, 2016 Report Share Posted April 6, 2016 I'm using the Uwell Crown Subohm tank with the .5ohm SS 316 w/Optional TC or Wattage mode compatibility. I heard pops from the tank like dry hits, then I must've burned the coil a little bit as well because of the taste and smell produced. The mod is fine, though. I need help with this since I know how to use the software except these Crown stainless steel coils with the nickel legs are a puzzle I don't enjoy tonight. Anybody know how to set up a .5ohm SS 316 Wattage Mode vaping (Kanthal style)? I appreciate your help. Link to comment Share on other sites More sharing options...
VapingBad Posted April 6, 2016 Report Share Posted April 6, 2016 You don't need to do anything special for any coils in wattage mode, just turn of temp limiting. Link to comment Share on other sites More sharing options...
