Asterr Posted April 14, 2016 Author Report Posted April 14, 2016 Hi. To make it short - before yesterday everything was fine. I plugged in my DNA to PC, so i can change some options in TC. Ok, done, I hit "Upload settings to device". After that, it won't let me change my profiles. They just don't show on screen at all, therefore I can't swap them.I tried googling it, making some changes in escribe, and none of these worked.Dunno what the problem is, but I know 1 thing - it's annoying as hell.Any solutions?Kind regards
VapingBad Posted April 15, 2016 Report Posted April 15, 2016 Do you mean you can't change between profiles on the mod (lock ohm/temp whichever is the big number by holding the up & down buttons for about 5 secs, then pressing up or down > 2 times to scroll to the profile and pressing fire to select)?Or is it a problem with the computer software EScribe?
Asterr Posted April 15, 2016 Author Report Posted April 15, 2016 You're right, I didn't state it clearly. I was in a hurry.Escribe works perfectly - it's just the mod. I can change between Stealth - Normal, I can lock ohms, I can lock Wattage, etc etc.It's just that after I lock it and press either - or + twice, it just shows me my locked screen, and nothing else. "Menu" where I can browse profiles just doesn't appear at all.
dwcraig1 Posted April 15, 2016 Report Posted April 15, 2016 Asterr said:You're right, I didn't state it clearly. I was in a hurry.Escribe works perfectly - it's just the mod. I can change between Stealth - Normal, I can lock ohms, I can lock Wattage, etc etc.It's just that after I lock it and press either - or + twice, it just shows me my locked screen, and nothing else. "Menu" where I can browse profiles just doesn't appear at all.I stopped at a vape shop that I go to occasionally to show the owner how to use the new firmware and we had that problem (maybe).What solved it was to add the various materials. It was as if there was nothing to change to, it fixed it.Edit: Let me add a bit more to this. In this situation we took a brand new Hana 200 from the display case and applied the beta firmware, there were no profiles previously set upOh, never mind...... it was materials that we couldn't change as they were all nickel. DUH
Asterr Posted April 15, 2016 Author Report Posted April 15, 2016 @dwcraig1Now that's interesting Glad you solved it, though.I think it will help to solve the problem - everytime I screw in a new atomizer (different coils of course), it asks me if it's a new coil. Like in TC. "New Coil? + Yes - No". It started happening exactly when I couldn't change profiles in mod. Btw, lemme try adding materials. Maybe it will solve it.Edit: Nope, didn't help at all.
dwcraig1 Posted April 15, 2016 Report Posted April 15, 2016 Asterr said:@dwcraig1Now that's interesting Glad you solved it, though.I think it will help to solve the problem - everytime I screw in a new atomizer (different coils of course), it asks me if it's a new coil. Like in TC. "New Coil? + Yes - No". It started happening exactly when I couldn't change profiles in mod. Btw, lemme try adding materials. Maybe it will solve it.Edit: Nope, didn't help at all.Something to consider might be to save your battery profile, copy down your case settings, screen setting, ect on paper and restore default settings with a hard reboot in the end. Then add everything back. I'm pretty much saying what I would do but not at all sure if it will solve it for you, can't see it hurting anything though as long as you keep all the settings.Might even re-flash the firmware too.
Asterr Posted April 15, 2016 Author Report Posted April 15, 2016 Alright, I'll try it in the evening as right now I'm not home
Asterr Posted April 18, 2016 Author Report Posted April 18, 2016 Restoring defaults didn't help. - but a hard reboot did.A funny thing - now the screen shows me temp settings. The only time I see wattage is when I hold + and -, when the mod is blocked. The heck. - fixed
dwcraig1 Posted April 18, 2016 Report Posted April 18, 2016 I do believe you just said it's fixed, love a good ending to a mystery.
blueridgedog Posted April 18, 2016 Report Posted April 18, 2016 It sounds like you have checked temp dominant for the profile...it will now let you pick between showing your temp settings or wattage settings based on your selection for each profile.
