Cracked screen!!! Can it be fixed.
Yes the screen will work, you just need to put a couple of bends in the cable to keep it clear of the fire button, but don't bend the first mm or two next to the glass.  The front plate unscrews from inside the battery compartment, you don't need to remove all the screws it should be obvious which one IIRC.
