jabbahoo Posted April 19, 2016 Author Report Posted April 19, 2016 I dropped my reuleaux dna200. The screen is cracked and no longer works. everything else works fine. I looked online and can buy a new screen. Will the screen I buy on this site work? and if so, is it a pain to install?
VapingBad Posted April 19, 2016 Report Posted April 19, 2016 Yes the screen will work, you just need to put a couple of bends in the cable to keep it clear of the fire button, but don't bend the first mm or two next to the glass. The front plate unscrews from inside the battery compartment, you don't need to remove all the screws it should be obvious which one IIRC.
jabbahoo Posted April 19, 2016 Author Report Posted April 19, 2016 Thanks for the quick reply VapingBad!! Do you know if there is a step by step online or a video floating around?
VapingBad Posted April 19, 2016 Report Posted April 19, 2016 There are probably some about fixing/bending the screen cable that will show every thing you need as Wismec didn't do it with the early mods, sorry no link.
BillW50 Posted April 19, 2016 Report Posted April 19, 2016 Just to add what VapingBad had stated. If you use EScribe, you can capture the screen at anytime with the Capture button under Themes. Also the DNA 200 Datasheet tells you how to replace the screen.
