antyac2108 Posted April 20, 2016 Author Report Posted April 20, 2016 Has anyone used or heard of this wire? Also if so what experience have you had using it or heard about using it.
dwcraig1 Posted April 21, 2016 Report Posted April 21, 2016 Well Zivipf has Nife 30 which is 70% nickel. The listed TCR is 520. Note Zivipf calls their Nife52 48.Here is Kanthal's data sheet for Nife70, note the composition. Steamengine lists Nifethal70 (alloy 120) TCR @525I assume that Zivipf's Nife30 is Nifethal 120, I have it, perhaps I'll give it a try tonight and report back.I'm a big fan of Dicodes nife 30 btw which is 30% nickel (I think)Interesting that you posted about it as it was already on my mind.
antyac2108 Posted April 21, 2016 Author Report Posted April 21, 2016 Well I was getting ready to do a wire order and came across it on kidney puncher. I also found a good review on Google when I searched for the wire.
antyac2108 Posted April 21, 2016 Author Report Posted April 21, 2016 I am going to order some tomorrow I think
dwcraig1 Posted April 21, 2016 Report Posted April 21, 2016 So I went ahead and made a couple of Zivipf Nife 30 coils, keep in mind that they are 70% nickel so that yields a fairly low resistance.Also the TCR is high so temp accuracy is easy for the board.My coils are 8.5 wraps, 2 mm id, 26 gauge wire, x2, that come out to 0.6? which is a bit lower than I prefer but still doable.I really see no real advantage using it over Nife48/52 but it is working well.
antyac2108 Posted April 21, 2016 Author Report Posted April 21, 2016 Did you do contact our spaced coils? Also can you dry burn with this wire?
dwcraig1 Posted April 21, 2016 Report Posted April 21, 2016 I do mainly contact coils, and dry burn it. Perhaps I shouldn't but I do.I used it all night at work, doing well.
antyac2108 Posted April 21, 2016 Author Report Posted April 21, 2016 Awesome I'm on kidney puncher right now ordering it
Hornisse Posted February 5, 2019 Report Posted February 5, 2019 NiFethal70 works perfect in TC mode with DNA. I also use NiFethal52, but sometimes I experienced temperature disturbances. NiFe70 is much more consistent and precise.
Chef Ginger Pants Posted March 6, 2020 Report Posted March 6, 2020 Does the Nifethal 70 need a new wire type? My ohms jump around like crazy when I use the NiFe70 in NiFe30 mode
retird Posted March 6, 2020 Report Posted March 6, 2020 Steam Engine has a calculator that can generate CSVs for custom materials.
Chef Ginger Pants Posted March 6, 2020 Report Posted March 6, 2020 Cool site. They don't have the NIFe70 wire type but definitely a good resource
dwcraig1 Posted March 6, 2020 Report Posted March 6, 2020 Nifethal 70 SteamEngine_NiFethal70-DNA200.csv Nife70 and Nife30 are generally the same wire. One lists Ni content and the other lists Fe content.
Chef Ginger Pants Posted March 6, 2020 Report Posted March 6, 2020 Im on a 75C, didn't think I could use the one on the site... but seems to be working thanks! 1
dwcraig1 Posted March 7, 2020 Report Posted March 7, 2020 2 hours ago, Chef Ginger Pants said: Im on a 75C, didn't think I could use the one on the site... but seems to be working thanks! If because it says DNA200, well at the time the 200 was the only board to use EScribe.......then he others came along. Even though it says DNA200 it is for all the Escribe capable boards with the exception of the Go board.
