Jbates2505 Posted June 26, 2016 Author Report Posted June 26, 2016 My HOBO DNA200 screen started acting up a few days ago and now it has completely stopped working The mod still works and everything seems to be fine on Escribe. Any suggestions?
retird Posted June 26, 2016 Report Posted June 26, 2016 Can you describe what the screen was doing before it went out completely?
Jbates2505 Posted June 26, 2016 Author Report Posted June 26, 2016 retird,the pixels started to act weird and it was almost like the screen could not keep up wit the mod
retird Posted June 26, 2016 Report Posted June 26, 2016 It could be a loose connection where the screen ribbon attaches to the board. The screen is replaceable if the pixels just disappeared a little at a time, usually caused by a cracked screen glass or damaged ribbon. Sometimes the ribbon gets damaged as it gets pinched due to contact at the fire switch repeatedly until it just goes out... Best guesses so hope this helps...
BillW50 Posted June 26, 2016 Report Posted June 26, 2016 Someone posted a script to run or something (was it VapingBad?) that returns a code whether the screen is faulty or not. But something that I would do until this is posted again or someone finds it... is in EScribe under themes tab, see all of those capture buttons? Pick any of them and when you press one of them it grabs what is suppose to be on the screen at the moment. If that looks fine, that is a good sign. Don't upload to your DNA200 or save or anything. As it will change that screen.
BillW50 Posted June 27, 2016 Report Posted June 27, 2016 Found it! And it was Brandon.Brandon said:attach the mod to the PC->Go to EScribe->click Help->About->Click the Evolv logo 7 times->open Device Monitor->on the left side of the screen next to Screen Disconnects, what does it say?https://forum.evolvapor.com/topic/68104-topic/?do=findComment&comment=912674
BillW50 Posted June 27, 2016 Report Posted June 27, 2016 Here is the extra debug information you get.
