BillW50 Posted June 26, 2016 Report Posted June 26, 2016 Well 1.0.42 will give you the latest DNA200 firmware. And 1.0.56 works with both DNA75 and DNA200, but it is missing the 02-27-2016 DNA200 firmware if you needed it. I said 02-23-2016 earlier, but it is 02-27-2016 (1.0.42). There is a 02-29-2016 (1.0.42) version too which is the same thing but has some non-English bugs fixed.
Jentz9517 Posted June 26, 2016 Report Posted June 26, 2016 BillW50 said:Well 1.0.42 will give you the latest DNA200 firmware. And 1.0.56 works with both DNA75 and DNA200, but it is missing the 02-27-2016 DNA200 firmware if you needed it. I said 02-23-2016 earlier, but it is 02-27-2016 (1.0.42). There is a 02-29-2016 (1.0.42) version too which is the same thing but has some non-English bugs fixed. ok , I was under the impression that people are bricking boards with (test) firmware.. I don't see 2/27/16 Anyhow I am going to load 2/29/16 1.0.42 then .56 I guess. That's safe
BillW50 Posted June 26, 2016 Report Posted June 26, 2016 Yes the beta that was bricking DNA200 mods is known as 05-02-2016 (1.0.51). You probably won't find it, but if you do run across it, don't use it.
BillW50 Posted June 26, 2016 Report Posted June 26, 2016 That 2016-02-23 date that I got EScribe confused with above is because that is the latest firmware version for the DNA200.
Jentz9517 Posted June 26, 2016 Report Posted June 26, 2016 Ok, I'm lost here I loaded 2/29 then updated then tried 5/6 and it wouldn't let me ? I need step by step instructions if you could
BillW50 Posted June 26, 2016 Report Posted June 26, 2016 It should let you install right over itself, unless you have 2016-02-29 still running.
Jentz9517 Posted June 26, 2016 Report Posted June 26, 2016 BillW50 said:It should let you install right over itself, unless you have 2016-02-29 still running.i think i closed out of it?, possibly not. i'll get it sooner or later.. thanx for the help Bill
Jentz9517 Posted June 27, 2016 Report Posted June 27, 2016 BillW50 said:It should let you install right over itself, unless you have 2016-02-29 still running.its says windows cant open this file type? when I try
BillW50 Posted June 27, 2016 Report Posted June 27, 2016 You downloaded this file:http://evolvapor.com/software/SetupES75.exeAnd Windows won't run it? This is the latest EScribe for both DNA75 and DNA200 (1.0.56).
dwcraig1 Posted June 27, 2016 Report Posted June 27, 2016 Jentz9517 said:its says windows cant open this file type? when I try Does it say it can't or advises against it?
Jentz9517 Posted June 27, 2016 Report Posted June 27, 2016 lol maybe it wasn't I will go check my laptop now. I tried the link that vaping bad has on his signature
Jentz9517 Posted June 27, 2016 Report Posted June 27, 2016 BillW50 said:You downloaded this file:http://evolvapor.com/software/SetupES75.exeAnd Windows won't run it? This is the latest EScribe for both DNA75 and DNA200 (1.0.56). well call me stupid I get software and firmware mixed up thanks it installed now!! Appreciate your help
Jentz9517 Posted June 27, 2016 Report Posted June 27, 2016 helps to install software then firmware hah oh well its good to go now..
