timbomfg Posted March 7, 2016 Author Report Share Posted March 7, 2016 So, i for one was one of the owners of a VT200 who had no issues whatsoever, and adored it other than its less-than-stellar battery life.Between you lovely people here, and DJSLB doing some "testing" i was able to get the mod's core settings populated and calibrated properly.However, i've sold that on, and bought the VT133 after deciding i'd rather have swappable batteries and limited power.But HCigar strikes again, there is NO OoTB config on the device bar a pretty crap battery curve for the VTC4s. I've since swapped out to HG2s and run the calibration on that without issue.However, what i dont have, is mod resistance, nor casing settings.I'm trying to find a little temp sensor to calibrate the box itself against, but mod resistance is going to prove tricky. I've been unable as-yet to find an M7x0.5 copper or brass bolt to try and test the resistance with.So, owners of the VT133, come forth, discuss, and perhaps between us we can get all the information together required to make this mod as good as it can be! Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 7, 2016 Report Share Posted March 7, 2016 What I and others have done is to solder the 510 of an old cartomizer or 510 adapter together to use as a tool for mod resistance. It works well, be sure to set mod setting to zero prior to running the test. Link to comment Share on other sites More sharing options...
timbomfg Posted March 7, 2016 Author Report Share Posted March 7, 2016 That's a good shout, i'm sure i have an old 510-ego adapter kicking around somewhere from my MVP days! Whatcha reckon, just a big glob of solder in the top of it, then stick a multimeter on the bottom once it's cooled to see what it shows? Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 7, 2016 Report Share Posted March 7, 2016 timbomfg said:That's a good shout, i'm sure i have an old 510-ego adapter kicking around somewhere from my MVP days! Whatcha reckon, just a big glob of solder in the top of it, then stick a multimeter on the bottom once it's cooled to see what it shows?Here's mine:I removed the insides and the rubber grommet and put the positive pin back in and filled with solder.(from the bottom) Link to comment Share on other sites More sharing options...
DrewBurton50 Posted March 7, 2016 Report Share Posted March 7, 2016 timbomfg said:That's a good shout, i'm sure i have an old 510-ego adapter kicking around somewhere from my MVP days! Whatcha reckon, just a big glob of solder in the top of it, then stick a multimeter on the bottom once it's cooled to see what it shows? If you do this I would appreciate a share of your result as I don't own a soldering iron.I am currently using 0.022 as the mod resistance which seems to work pretty well (the value given on djlsbvapes for the vt200 ) I too owned and loved the vt200 before selling it to buy this device. I am loving this. The battery life is excellent. Just hope VapingwithTwisted420 didn't put too many people off this device when he did a full review with the battery door installed the wrong way round. Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 7, 2016 Report Share Posted March 7, 2016 0.022? surely can't be the correct setting, he (Daniel) must have made a typo. A figure of 0.0022? would be more believable. All 4 of mine are close to 0.003?. I seem to recall a correction made in the comments on his site on that, not sure though. Link to comment Share on other sites More sharing options...
VapingBad Posted March 7, 2016 Report Share Posted March 7, 2016 0.022 ? seems very high to me as well, all the mods I have made and the Rolo are between 0.003 ? and 0.004 ?. Link to comment Share on other sites More sharing options...
timbomfg Posted March 8, 2016 Author Report Share Posted March 8, 2016 Checking my config for my old VT200, yeah i had 0.022 tooCurrently running the case analyser as it appears to be about 10degC out, causing all tc modes to run a bit rough! Link to comment Share on other sites More sharing options...
Johan Posted March 8, 2016 Report Share Posted March 8, 2016 0.022 is a bad number than originated a djlsb. I got ~0.004 as did several others. That would be a better guess until someone checks it. I got a very nice little copper 510 plug from one of the members here (name escapes me at the moment) made for the purpose. Link to comment Share on other sites More sharing options...
timbomfg Posted March 8, 2016 Author Report Share Posted March 8, 2016 IIRC weren't there two different 510 connections over the course of the VT200s production run? Maybe that'd account for it?I have to say, based on what i'm seeing between a few other mods i own, my VT133 could be around 0.01 out. I need to either build a 510 blank to test, or see if the gent on here who makes the copper slugs with the M7x0.5 thread would ship the the United Kingdom of Tea and Scones. Link to comment Share on other sites More sharing options...
timbomfg Posted March 8, 2016 Author Report Share Posted March 8, 2016 Right...Sat my VT133 in my server room for a few hours. Room is kept at 18degC using a fairly decent A/C unit, and the multiple readings around the room confirm the room temp.Unit left to run through its process over the 4 or so hours it takes, results are as follows: Link to comment Share on other sites More sharing options...
timbomfg Posted March 8, 2016 Author Report Share Posted March 8, 2016 First few hours since running this, i'm getting a far more consistent vape, albeit at a lower temp than i would expect Link to comment Share on other sites More sharing options...
Jentz9517 Posted March 9, 2016 Report Share Posted March 9, 2016 What batteries are you getting those results with? What is your mod resistance value? Link to comment Share on other sites More sharing options...
timbomfg Posted March 9, 2016 Author Report Share Posted March 9, 2016 As mentioned, i have no mod resistance set yet as i haven't bought/built a tool to test it.I'm running a fresh married pair of LG HG2s Link to comment Share on other sites More sharing options...
timbomfg Posted March 10, 2016 Author Report Share Posted March 10, 2016 Update: expecting a 99.9% copper calibration tool within the next couple of days with any luck! Link to comment Share on other sites More sharing options...
scooby Posted March 10, 2016 Report Share Posted March 10, 2016 timbomfg said:Update: expecting a 99.9% copper calibration tool within the next couple of days with any luck!Did you manage to source this in the UK? Link to comment Share on other sites More sharing options...
timbomfg Posted March 10, 2016 Author Report Share Posted March 10, 2016 scooby said:Did you manage to source this in the UK?I did, apologies i should of thought to share:http://signaturetips.com/calibration-tool-for-dna200-devices.html Link to comment Share on other sites More sharing options...
scooby Posted March 10, 2016 Report Share Posted March 10, 2016 timbomfg said:I did, apologies i should of thought to share:http://signaturetips.com/calibration-tool-for-dna200-devices.htmlThat's great, thanks very much. Will just have to resist ordering some drip tips as well! Link to comment Share on other sites More sharing options...
timbomfg Posted March 11, 2016 Author Report Share Posted March 11, 2016 Arrived: Tested: Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 11, 2016 Report Share Posted March 11, 2016 timbomfg said:Arrived: Tested: So you did set mod resistance to zero and upload to the mod first right? Link to comment Share on other sites More sharing options...
timbomfg Posted March 11, 2016 Author Report Share Posted March 11, 2016 Zero'd the mod by doing a hard-reset of the mod yeah Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 11, 2016 Report Share Posted March 11, 2016 timbomfg said:Zero'd the mod by doing a hard-reset of the mod yeahBy setting mod resistance to zero before checking mod resistance with your tool. Link to comment Share on other sites More sharing options...
timbomfg Posted March 11, 2016 Author Report Share Posted March 11, 2016 Yes Link to comment Share on other sites More sharing options...
dwcraig1 Posted March 11, 2016 Report Share Posted March 11, 2016 I'm still at work without my tool, not sure how the cold ohms correlates to raw ohms. Does it change when you screw it in and out? Link to comment Share on other sites More sharing options...
timbomfg Posted March 11, 2016 Author Report Share Posted March 11, 2016 As far as the documentation seems to imply, cold ohms IS raw ohms. It's the base ohm of the item in question. It fluctuated whilst the tool was still loose, but the moment it got to the point of being "tight" it held 0.004 Link to comment Share on other sites More sharing options...
