kentam Posted March 7, 2016 Author Report Posted March 7, 2016 Hi All,I am new to DNA 200 with SS430 wire.My current situation is my coil build as say 0.88 ohm, and if I fire it in DNA 200 watt mode LCD show during fire is start from 1.1ohm, but the Atomizer is showing lower than 1.1ohm feel strange.I use SS430 mainly want to make the TC work, because I am a bit afraid the side effect of NI200.So most my try and error is in tc mode.In tc mode.If I lock the coil ohm by software to 0.88, the mod will just fire in a very weak power. But if I add up some small margin... say a 0.5 ohm coil lock as 0.58 and a 0.88 coil lock as 1.1 it will fire up normally.Anyone have same experience? I do want to hear what you think and how you resolve.Many thanks.
VapingBad Posted March 7, 2016 Report Posted March 7, 2016 I would not lock resistance unless I had a connection issue as you are disabling the DNAs ability to more accurately measure the resistance as the coil cools. I think locking at 1.1 ohm it will never reach temp so effectively be in power mode. You may need to raise the temp if the wire is not a great match with it's profile/TFR/curve.
kentam Posted March 7, 2016 Author Report Posted March 7, 2016 Thanks VapingBad,Can you give me some source of SS430 profile / TFR / curve?Now I am using cvs from steam engine.
kentam Posted March 7, 2016 Author Report Posted March 7, 2016 Anyway thanks for your feedback / reply.
dwcraig1 Posted March 7, 2016 Report Posted March 7, 2016 http://www.steam-engine.org/wirewiz.aspYour 1.1 ohm doesn't sound right to me unless your using really thin wire (32)Get your files from Steamengine and compare your build with coil builder figures.Edit: Steamengine, I guess you already said that.
kentam Posted March 7, 2016 Author Report Posted March 7, 2016 Thanks for dwcraig1My coil in the tank is SS430 28g 2.5 12warpsohm meter = 0.89mod 1 = 0.88mod 2 = 0.9mod 3 DNA 200 with Amotizer Analyzer = 0.961 (jumping up and down in very small margin)mod 3 DNA watt fire = 1.11 ...strange?
dwcraig1 Posted March 7, 2016 Report Posted March 7, 2016 3 different DNA200 mods? Only a problem with #3?
kentam Posted March 7, 2016 Author Report Posted March 7, 2016 No, sorry for make you confuse...They are other mod with different chips I just use that to proof the build is solid.
dwcraig1 Posted March 7, 2016 Report Posted March 7, 2016 I'd be looking at the 510 socket.See this post I just made in another thread, maybe try that.https://forum.evolvapor.com/topic/66823-topic/?do=findComment&comment=901046
kentam Posted March 7, 2016 Author Report Posted March 7, 2016 ok I put a very short NI200 in a old kennedy rda, and the ohmmeter measure is 0.01 and aa is show 0.0099 show my mod res is set correctly.
Jentz9517 Posted September 2, 2016 Report Posted September 2, 2016 received CW ss430 today and wondering why it rides the TEMP SET line perfectly but with anemic vape with TCR 138 ? then use dwcraig recommended 238 which falls short of TEMP SET but gives responsive vape allbeit lacks density and moisture? then play around down the TCR scale to say 200-210 it gets closer to TEMPSET but with about the same Lackluster vape? I guess my main question is why the anemic vape at the wires standard TCR value but shows as its reading the wire correctly to be able to ride the TEMPSET line?
dwcraig1 Posted September 2, 2016 Report Posted September 2, 2016 I'll try here, might not be exactly right but here goes. The accuracy of the temp line for example 450F is determined by the accuracy of the TCR. With TCR of 0.00138 assuming it's way off the temp even though it says 450F may be only 300F (just guessing at the difference)
