510husky Posted September 2, 2016 Author Report Posted September 2, 2016 Hi hope someone can help new to this My vt133 was dropped now won't charge could there be something that would become loose inside or am I onto a lost cause Thanks
VapingBad Posted September 2, 2016 Report Posted September 2, 2016 Not got a VT133, but sometimes when you drop 18650 mods the weight of the battery flattens the battery connection/spring and you can normally bend it back.
510husky Posted September 3, 2016 Author Report Posted September 3, 2016 Thanks for the reply Bit more info got it hooked up to escribe and in diagnostics it reads cell 1 - 5.02v cell 2 - 0v
BillW50 Posted September 3, 2016 Report Posted September 3, 2016 Oh that isn't good. Not will it even charge, but it shouldn't even fire with those readings. Unless there is juice in there that can be cleaned out, it needs to be RMA'd to Evolv. I have five VT133s myself.
510husky Posted September 4, 2016 Author Report Posted September 4, 2016 after reading a few posts i set it to power mode in escribe and it works on fully charged batteries now thinking it might be the fuse is there a way i can test thisthanks
dwcraig1 Posted September 4, 2016 Report Posted September 4, 2016 If it works, even lights up with batteries, without the data cable supplying power then it's not the fuse.Or perhaps did you mean that you set it to "power supply"Your post #3 pretty much indicates it needs to be RMA'dhttps://helpdesk.evolvapor.com/index.php?a=add
