Proto Posted October 26, 2016 Author Report Posted October 26, 2016 It's consistently only ever charging at 0.1amp. I've tried different cables and sources but they are all the same. i have other setups that are identical that charge just fine.I've tried a full firmware reset and tried changing the charge current in the monitor screen.I made a few of them and this is the only one doing this, it seems like a software thing because of how consistent it is, i can limit the usb current to 0.05 and that works just fine, it just won't raise higher than 0.1It just started only doing this recently, I've had the batterys fully charged before from the devices usb port and they were working just fine, my mate said it was only charging at 0.1 and he gave it a wiggle and it fixed it but i didn't get to see so i really don't know.I might take it apart and resolder it but i really don't think that's it.Spec:Dual 18650 30QDNA 200 in dual battery 133modeEdit pic:
VapingBad Posted October 26, 2016 Report Posted October 26, 2016 It maybe your board temp it high @ 126 F, I don't know the exact numbers, but they do reduce the charge rates when the temp get too high. Only normally comes up with plastic cases as metal cased with good mountings act as a heat sink for the board. Try letting the mod cool, maybe put board temp & USB current on the charging screen temporally, and see if it will charge faster.
Proto Posted October 26, 2016 Author Report Posted October 26, 2016 I think you're right, i'm not too sure what a Fahrenheit is because i work in Celsius. I plugged it in again and it worked fine till it hit 125fAnd apparently my room is 43 degrees...i'll have to take it apart and check the soldering.
Proto Posted October 26, 2016 Author Report Posted October 26, 2016 Wait, i just re-plugged it and it was below 120 and still at 0.1amp...wtf this chip is crazy.
VapingBad Posted October 26, 2016 Report Posted October 26, 2016 It will also be slow if the battery is nearly full, all Li chargers slow as the battery gets close to full. IDK if that's what is happening though.
dwcraig1 Posted October 26, 2016 Report Posted October 26, 2016 This is a total stab in the dark but here goes......is the battery by chance set to LiFePO4 instead of Lithium Polymer?
Proto Posted October 27, 2016 Author Report Posted October 27, 2016 Ok, so it was my fault, idk what happened but i just resoldered my wires and connections and the temps dropped to 80~
