Deleting Profiles ? ? ?
Hi everyone...
i am using a VT75 Nano and ony use 2 Profiles... Watts and SS316...
Is there a way to delete Profiles from the device so that i have only the 2 left that i need?
I tried Google without any luck
Thx in advance
You will always have 8, what you can do would be to make profiles 3 & 4 the same as 1 & 2. Do the same with 5 & 6 and 7 & 8.
That way you will always have your desired change one click away, either up or down.That's about all that can be done,
After doing what @dwcraig has mentioned you can then go ahead and remove the extra 'materials' from your device as they will no longer be associated with a profile, if you wish.
Or, if you use different atty's with different wattage, temp settings, etc for only watts or 316l wires you could set up profiles (up to 8) for each wattage, temp setting, etc. of each wire.
