What's up guy's. My partner has came across a puzzling issue. Has anyone used battery tubes in a 133 of so do you have a diagram. Everything is wired exactly like you would on a sled and nothing happens
Are the tubes isolated (electrically) from the case?
I have not seen a diagram as it all depends how you are fitting the tubes in the case, because the cells are in series you can't have both tubes grounded to the case.
It could just be that the screen cable has got damaged, try hooking it up to EScribe Device monitor and looking at the cell levels, also on the Themes tab you can get a capture of what the screen should be showing.
Alright we have changed the cells to 2 in escribe and everything reads in that program. Once we unplug it from the USB with cells inserted nothing happens. I know the problem is not getting the power to the board at that point, but we have used every suggested diagram given
If you can determine pack is present at B+ and B- using a meter then you need to check for pack voltage between B- and the upper (towards center) end of the fuse.
Keep in mind that the board is coated so it may be difficult to make a connection at the fuse.
Or without battery connected check for continuity between B+ and upper end of fuse.
