raidermatt Posted February 16, 2017 Author Report Share Posted February 16, 2017 So I'm vacuuming my garage and the cord gets caught so whip it to try and free it up. I succeeded in freeing up the cord but managed to knock my reuleaux DNA 200 off my work bench and onto the linoleum floor. When I pick it up I have the infamous blank screen so I hook it up to escribe and it's showing everything is normal and working fine. So I ordered the 12$ screen from evolv in hopes that it's a quick, inexpensive fix. I signed up for this forum and have found an overwhelming amount of info on reuleaux screens and now I'm worried it could be the fuse. Can someone hook me up with a link/video on replacing the screen. I've spent the past day on the forum highlighting/bookmarking the only problem I have now is I've got 30 topics to go back thru and read. OVERWHELMED!!! Link to comment Share on other sites More sharing options...
retird Posted February 16, 2017 Report Share Posted February 16, 2017 Even with a broken screen it should vape....does it? Does it show normal readings while vaping with it connected to Device Monitor? Link to comment Share on other sites More sharing options...
VapingBad Posted February 19, 2017 Report Share Posted February 19, 2017 When you drop those the top and bottom can bend causing the batteries not to fit well, check the gap between the battery cover and body are even at the top and bottom, if not just take the batteries out, put on a firm surface and push back with the palm of your hand. Link to comment Share on other sites More sharing options...
