Spector NS5 RD Posted December 6, 2016 Author Report Share Posted December 6, 2016 For people who need the battery curve (CSV) for TWO Sony VTC5A batteries (brand new), below is my result from running Battery Analyzer. This test was ran using a Vaporshark Vaporflask DNA133 set to the maximum of 108 watts (because of the 6v limit) with .33 ohm load.Sony VTC5A Battery Curve (2S)THEIR CAPACITY (WATT HOURS) IS - 14.051I USED A "CELL SOFT CUTOFF" OF - 2.6V 2S Sony VTC5A Battery Curve (14.051).csv 1 Link to comment Share on other sites More sharing options...
DNA Papst Soulvape Posted December 7, 2016 Report Share Posted December 7, 2016 how many wh comes out with the vtc5a? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted December 7, 2016 Author Report Share Posted December 7, 2016 soulvape said:how many wh comes out with the vtc5a?it's stated in the download link - 14.051 wh's Link to comment Share on other sites More sharing options...
fibercarbon Posted December 9, 2016 Report Share Posted December 9, 2016 I LOVE Sony VTC5A. BEST 18650 you can buy Link to comment Share on other sites More sharing options...
ez.valdez Posted December 22, 2016 Report Share Posted December 22, 2016 Hey guys. I'm fairly new to DNA's and I'm looking for a little advice. I have a Boxer DNA 167(250) and I'm using 2 SONY VTC5A batteries. Using the setting above, do I also set the Kanthal Power Limit to 167? I assume so but just wanted to make sure. Thanks in advance. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted December 22, 2016 Author Report Share Posted December 22, 2016 ez.valdez said:Hey guys. I'm fairly new to DNA's and I'm looking for a little advice. I have a Boxer DNA 167(250) and I'm using 2 SONY VTC5A batteries. Using the setting above, do I also set the Kanthal Power Limit to 167? I assume so but just wanted to make sure. Thanks in advance. welcome to the forum ez.valdez. yes, set the max knathal limit to 167 when using the DNA 250 in 2 cell operation. Link to comment Share on other sites More sharing options...
ez.valdez Posted December 22, 2016 Report Share Posted December 22, 2016 Awesome, thanks again! Link to comment Share on other sites More sharing options...
Theplasticbling Posted January 6, 2017 Report Share Posted January 6, 2017 Hey everyone. Im currently using dual vtc5a's in my finder 133, and the batter indicator seems to be off. Escribe says my batterys are at 3.51 volts but the indicator is still at the very bottom. I used 14.051 for my watt hours. Is this normal? Thanks. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 6, 2017 Author Report Share Posted January 6, 2017 Theplasticbling said:Hey everyone. Im currently using dual vtc5a's in my finder 133, and the batter indicator seems to be off. Escribe says my batterys are at 3.51 volts but the indicator is still at the very bottom. I used 14.051 for my watt hours. Is this normal? Thanks.did you use the CSV along with the watt hour setting? Link to comment Share on other sites More sharing options...
Theplasticbling Posted January 7, 2017 Report Share Posted January 7, 2017 ChunkyButt200 said:did you use the CSV along with the watt hour setting? Yup, used all the settings shown in the first post Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted January 7, 2017 Author Report Share Posted January 7, 2017 you're saying you're still able to vape for a lot longer, even after the battery bar is empty? increase the watt hour value. up it to 15 or 16 somewhere around there. Link to comment Share on other sites More sharing options...
Theplasticbling Posted January 7, 2017 Report Share Posted January 7, 2017 ChunkyButt200 said:you're saying you're still able to vape for a lot longer, even after the battery bar is empty? increase the watt hour value. up it to 15 or 16 somewhere around there. Correct, for a while actually. Shouldn't they be the same as yours tho? They are brand new vtc5a's? Edit: the batteries finally died and I threw them on an external charger, they went all the way down to 3.1 and 3.14 volts. I've never seen any batter go that low on any of my mods. Is that safe? Do you think my batteries are damaged from going that low? I used all the settings you used so I'm kind of lost. Am I having issues because I didn't fully charge my batteries before putting them in my mod? I put them straight in when they came in the mail. Link to comment Share on other sites More sharing options...
VapingBad Posted January 7, 2017 Report Share Posted January 7, 2017 That's fine, they are usually specified down to 2.5 V resting voltage, they would have been around 40% charge when you got them so yes that would explain your issue. Link to comment Share on other sites More sharing options...
Theplasticbling Posted January 8, 2017 Report Share Posted January 8, 2017 VapingBad said:That's fine, they are usually specified down to 2.5 V resting voltage, they would have been around 40% charge when you got them so yes that would explain your issue. Ok thanks for the info, so just to be clear after throwing them in the mod fully charged it should be accurate, and the batteries normally drain to that level and no damage was done? Link to comment Share on other sites More sharing options...
VapingBad Posted January 8, 2017 Report Share Posted January 8, 2017 Theplasticbling said: Ok thanks for the info, so just to be clear after throwing them in the mod fully charged it should be accurate, and the batteries normally drain to that level and no damage was done?Yes to all and they will drain to low 3 point something volts, mainly this is from the low cut off setting that is the min voltage under load where the board reduces power to protect your battery and you would never drain your batteries that low. Link to comment Share on other sites More sharing options...
Apithanos Posted January 12, 2017 Report Share Posted January 12, 2017 Hi guys. I am new to the forum and i have some issues. I ve build a dna250 box 2Ã18650s lg hg2. Set it to 3.02 scc at first. The problem is i dont get the battery weak notification even the bar is completly empty. I ve changed the scc to 3.2 v but nothing. Allso when the batt bar goes from half and below the power is very weak. Any help? Thanks in advance. Ps. Sorry if my english ar not good Link to comment Share on other sites More sharing options...
VapingBad Posted January 12, 2017 Report Share Posted January 12, 2017 You can turn the weak battery message on or off on the display tab in Escribe, when it's off the battery icon flashes instead. Link to comment Share on other sites More sharing options...
Apithanos Posted January 12, 2017 Report Share Posted January 12, 2017 its not even flashes. no line at all in it and its just steady Link to comment Share on other sites More sharing options...
ez.valdez Posted January 22, 2017 Report Share Posted January 22, 2017 I am using the settings above for the 2 Cell VTC5A's on my 250 set up and get weak battery too at like 40% Battery life. .28ohm Build at 100w. Does that sound normal?Apithanos said:Hi guys. I am new to the forum and i have some issues. I ve build a dna250 box 2Ã18650s lg hg2. Set it to 3.02 scc at first. The problem is i dont get the battery weak notification even the bar is completly empty. I ve changed the scc to 3.2 v but nothing. Allso when the batt bar goes from half and below the power is very weak. Any help? Thanks in advance. Ps. Sorry if my english ar not good Link to comment Share on other sites More sharing options...
VapingBad Posted January 22, 2017 Report Share Posted January 22, 2017 ez.valdez said:I am using the settings above for the 2 Cell VTC5A's on my 250 set up and get weak battery too at like 40% Battery life. .28ohm Build at 100w. Does that sound normal?It depends on the batteries and the low cut off setting, basically the board is seeing at least one of the cells hitting the low cut off under load. If your batteries are about 3.4 V (guess for 40%) the board would be drawing 15 A and the sag you are seeing is resting battery V - low cut off V. So if you have a high value for low cut off like 3.09 V 0.21 V sag sounds reasonable, try setting it to something more reasonable for 18650s like 2.8 V. Dirty or weak battery connections can also cause excessive sag. Low cut off is for the battery voltage under load (while firing) and not the resting voltage. Link to comment Share on other sites More sharing options...
ez.valdez Posted January 23, 2017 Report Share Posted January 23, 2017 Copy, thank you. I have it set to 2.6 and just wanted to make sure that was normal and I wasn't messing it up. heheVapingBad said:It depends on the batteries and the low cut off setting, basically the board is seeing at least one of the cells hitting the low cut off under load. If your batteries are about 3.4 V (guess for 40%) the board would be drawing 15 A and the sag you are seeing is resting battery V - low cut off V. So if you have a high value for low cut off like 3.09 V 0.21 V sag sounds reasonable, try setting it to something more reasonable for 18650s like 2.8 V. Dirty or weak battery connections can also cause excessive sag. Low cut off is for the battery voltage under load (while firing) and not the resting voltage. Link to comment Share on other sites More sharing options...
mehmet ayata Posted January 25, 2017 Report Share Posted January 25, 2017 tahnks Link to comment Share on other sites More sharing options...
Knowhere Posted January 30, 2017 Report Share Posted January 30, 2017 Hello,I am new to this forum.Can I use this discharge profile for a single 18650 SONY VTC5A?Thanks! Link to comment Share on other sites More sharing options...
dwcraig1 Posted January 30, 2017 Report Share Posted January 30, 2017 Knowhere said:Hello,I am new to this forum.Can I use this discharge profile for a single 18650 SONY VTC5A?Thanks! Just change the watt hours to reflect the number of cells. Link to comment Share on other sites More sharing options...
Noesitium Posted April 4, 2017 Report Share Posted April 4, 2017 Hello This is my first post and I am not sure if this is the correct spot to get the help I need.However I bought the Therion DNA 166 today and a couple of VTC5A's. I then browse the forum for the battery settings and found this topic but I am unable to download the .csv file from the first page.My account just got approved (Confirmed on mail) But it still won't allow to download the file. Am I missing something? Again first post from a completely new user on the forum Link to comment Share on other sites More sharing options...
