Pulsing tempature control problem
TimTim32
Hi,
I recently bought a VT75 Nano. And i'm having some problems with it. It seems everything is working fine, the ohm reading is stable and i did try to lock the ohms at room temprature but is still seem to be pulsing to keep the temprature.
Here is a picture of what I run into.
What kind of atomizer/coil are you using?
Edit: The reason I ask is... if you look closely at the screenshot you posted, you will notice that the 'Live Ohm' graph is fluctuating up & down, coinciding with the spikes & sags in temp, voltage & wattage...seems you may have unstable resistance when the coil is heated up...
I'm using a Goblin v3 Mini with an spaced SS316L coil of 0.33 ohms.
But the problem seems to be fixed thanks to VapingBad. I opened the mod today and tightened the ground screws, one of them was not tightened all the way.
Thank you VapingBad and giz_60 for the great support!
Cool...even though I haven't been having any issues with my Nano, I opened it up today & found 2 of 3 screws loose...perhaps the assemblers need some torque screwdrivers...:D  Very easy mod to access the board though...:thumb:
