20 hours ago, davidealda said:
I didnt remove the pack..I know that the battery level was very low and then i didnt use it for a week..then i plug it and this is the result..
Then most likely you need a new lipo. I would start there. The closest thing i found to direct a replacement is this >>>>>>>>
https://www.ebay.com/itm/UPGRADE-LIPO-BATTERY-1300mAh-3S-11-1V-EFUSION-VAPECIGE-CUSTOM-EVOLV-DNA-200-250/272517143930?hash=item3f73499d7a:m:maVwXKjZiS5g_nUNSbq71Sw:sc:USPSFirstClass!16148!US!-1
If the new lipo does not fix the issue then contact the manufacturer and Evolv.
@davidealda
I just opened my Vapecige Vtbox200 and disconnected the JST (balance) plug leaving the main power wires connected.  Showed 0 volts for cells 1, 2, 3 as well as pack.
A good way to check to see if this is balance connector related  if you don't have a volt meter would be to switch from battery to power supply in Escribe and see if the mod then turns on.
  • Like 3
  • 7 months later...
You're going to want to get to xt30 connectors
