Triade DNA250 and VTC5
FerdinandMac
  • 1 month later...
i would love to have 3 vtc5 profile for triade250 too. thanks in advance.
btw i am currently using this and it seems to be close to accurate for now. this is from some other device, not sure if it is ok to use that way though.
my capacity is at 28,86
soft cutoff is at 2.86
"Battery Charge (%)","Cell Voltage (V)"
0,2.8699951171875
0.764122068881989,3.00999450683594
2.14553499221802,3.13999938964844
3.12241244316101,3.19999694824219
5.66648960113525,3.27000427246094
17.8894462585449,3.41999816894531
45.2599983215332,3.61000061035156
89.0636749267578,4.02999877929688
92.7164764404297,4.05000305175781
98.1851959228516,4.1199951171875
100.001098632813,4.19000244140625
and thanks to giz_60
it is now
0,3.00999999046326
2.56157636642456,3.10999989509583
10.0390691757202,3.32999992370605
17.5199604034424,3.47000002861023
31.7071533203125,3.61999988555908
53.4024124145508,3.8199999332428
65.242057800293,3.90000009536743
80.2480010986328,4.05999994277954
92.4953308105469,4.1100001335144
98.4202499389648,4.15999984741211
100,4.21000003814697
  • 3 weeks later...
Hello
giz_60 said:
In the 'Mod' tab...
Why only 9 Wh?
You need to consider the total voltage of the three batteries.
The nominal voltage of a single battery VTC5 3.6 volt
hence the nominal voltage of the three batteries is equal to 10.8 volts.
You need to specify the total nominal voltage of three batteries
here are my settings
Triade DNA250 3xVTC5(my conf.).csv
giz_60 said:
That screenshot was taken from the Evolv default setting...wasn't referring to the Wh's in that post...but rather, how to load a .csv file...
this is the standard chart from the default settings for Triade DNA250
I changed the numbers in the calculator battery.
You mean to load the settings in the mod?
__________3.jpg  And upload the file which you downloaded earlier
__________4.jpg  Then save the settings in a mod
That's all. Mod is ready to work.
If you open Escribe to the DNA 250 version with no device attached...this is the screen you will get...which is what was used in the screen shot you were originally referring to...was only using this as an example to show how to load a .csv file into his device...
Well friend, no problem. I hope these tips will help novice users. Thank you for your file (.csv) I'll upload it into my mod later.
  • 1 year later...
36 minuti fa, Lanzarotechris ha scritto:
Maybe a stupid question, not shure...
Can I use this csv file on my Triade DNA250C as well ?
Would there be a difference between DNA250 and DNA250C ?
My gutt says "no... its the batteries, stupid !"
But as I said, not 100% shure... so when in doubt, better ask, right ?
Trust your gutt! You can use it 100%
Thanks,...
I always can rely on my gutt,... good to know 😉
...and congrats to your 1st post  *hehe*
Me myself started today as well... guess that makes us the newbies...
Welcome !
(still try to work things out... for example where can I edit my signature for my posts ?)
grazie ;-
Edited by Lanzarotechris
added italian
In questo momento, Lanzarotechris ha scritto:
Thanks,...
Welcome !
I'm not used to post in the forum, but i can assure you i've been  using dna boards almost a couple years now. So you can trust your gutt (and me aswell ;-) )
