JMat76
Everything posted by JMat76
  1. I just updated all the links and it should be good now. I don't know why it wasn't updating but I checked them and they should all be 3.4 now.
  2. I fixed it last night, download and install it again and it should have 3.4.
  3. Check out version 3.4, added a toggle for your request.
  4. As far as I am aware of you can only change that with the escribe software in the theme designer. I would love to be able to add it to my current theme to adjust on the mod but that option is not available as of yet.
  5. Thank you for the response and I am glad you are happy with the update. I've been working on just how to implement it for a while and just couldn't really figure out the best option to but I am very pleased with the way it is now. Hopefully everyone who uses temp control over replay will love this option.
  6. Version 3.5
    6,647 downloads
    Several modifications keeping the overall default Evolv theme look. Main screen "Firing" now red when firing as well as all menu or status bars. On main screen when not in active Replay saved puff you can select the ohm reading to shortcut you to the Coil Info screen. Settings changed to Menu for new menu / settings platform Most "Back" buttons removed and scroll up of down off the screen to go to the previous screen. Watts now adjustable in 1 watt increments instead of .1. Temp adjustable in 5 degree increments. New menu platform dived into Profile, Puff Info, Coil Info and Settings on main menu. New coil install screen now has cold ohm temp for new coil and old coil resistance and temp when deciding on new coil or keeping old settings. Profile Menu has added cold ohm temp with current ohm reading and coil material setting added. Also added is the availability to have advanced preheat settings with the Preheat+ toggle when temp control is active. Puff Info screen enhanced with chart and ability to change wattage and or temp for dialing in a perfect puff. Also the addition of several live readings of the last puff. Live ohms, room temp,average power, puff duration, puff volts, puff amps, and average puff temp, and max puff temp when in temp control. When a non-temp sensing coil is installed gives you current battery % instead of temp. Recording Screen with new additions to be able to monitor with every puff. New Coil Info screen added with time, battery %, current profile, coil material, cold ohms, live ohms, coil temp, ability to remeasure resistance, and ability to lock ohms. New settings menu with System, Display, Device, and About. System gives you date, time, 12 / 24 hr, F or C temp, max puff time and serial number. New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unlock device sequence. Device screen now has power bank settings, and battery voltages for up to 4 batteries. About Menu with Lifetime puff count, Theme revision, current firmware, current revision, edition, current puff count, puff count total energy, and reset to take you to a rest statistics screen. Thanks to everyone on the Evolv forum for ideas and themes to give me inspiration for this theme! Evolv Default Enhanced 250C.ecigtheme Evolv Default Enhanced 250C.ecigtheme
