conradisrugged
conradisrugged's Achievements
  1. Hey gang, One of the reasons I wanted a DNA device was to replace the chip or screen if anything went wrong and not having to buy a new housing etc... I had about 7 weeks ago cracked the screen on my Lost Vape Paranormal 250C by being an idiot and walking into a table while it was in my pocket, I live in South Africa and reached out to Evolv consulting about repair, they referred me to an international partner. Not having the money for shipping I opted to buy a replacement screen for $14 including shipping and replace it myself, I have just completed this task. It was an amazingly awesome experience taking my mod apart and successfully replacing the screen. I only had to wait 6 weeks on shipping which is the international standard toSouth Africa, it was well worth the wait considering I now have my mod back in working order! Kudos Evolv for having created a system that is not closed off. A very happy customer over here! Conrad
  2. Kanthal coils are exactly for that, wattage mode. The wires resistance is too stable to be used in temperature mode as there are no fluctuations in order to control the temperature. Like I said find a temperature sensing wire or coil like stainless steel and use that for temp control or replay, Kanthal can only be used in wattage mode.
  3. Firstly you need a temp sensing wire like Stainless Steel or Titanium or Nickel, secondly with the right theme you can do everything on the mod or I have in anyway.
  4. Version 1.0.0
    600 downloads
    Very simple No Man's Sky theme. No ~replay functionality.
  5. Hey guys, Please just sit tight, as another member said its a firmware issue, its being worked on and its true, just trust us, please just be patient for the next few days. Kind regards, Conrad
  6. As far as I understand, Replay is supposed to give you the same flavour by reading and changing a variety of parameters. So if you were to fire at 45 watts on a freshly primed coil, the vapor and warmth might be higher compared to say 8 puffs later, as Replay will try reproduce the same flavor by changing the parameters, so when you initially fired at 45 watts it now fires at 10 watts to get the last bit of juice out of the cotton without actually burning the cotton, this would result in lower watts and a colder vape but the flavour would be relatively the same.
  7. It’s a known issue and a topic for it has already been made.
  8. Hold on Jetro! I'm using N80 framed staple twisted wire on my one tank I use most of the day, is it compatible with Replay or do I have to change some settings in Escribe?
  9. Just a little update... Since I have restored to defaults and have done a soft and hard reboot I don't seem to have this issue as drastically as I did before. I did this on Wednesday 16th May, so more than a week ago. What I have noticed is that on the odd occasion when the device hasn't been used for 4 - 5 hours, I would need to press the fire button twice for it to wake, but its within a second or so. I for some reason have chosen to charge my batteries within the device so I couldn't definitively say with the device sitting over night for 8 - 10 hours how it reacts to booting up after such an extended period of deep sleep. Last night I had put in a fresh pair of batteries for my good night vape and my other 2 pairs of batteries were in the external charger, so I didn't really see the point of charging using the device in anyway. So this morning I wake up and i'm expecting to have to plug the device in using a USB cable to power it on, but first I just press the fire button, and too presses in succession and it boot up/woke from sleep within a second or so. I'm not sure what has caused this to be reduced however I'm using the stock standard theme with the only addition being that I put the puff counter on the screen. I'm not sure if this information will help anyone but it seems to have improved but not totally fixed my problem, in the past I would have boot delay of up to a minute sometimes 2 minutes, now its a second at most.
  10. Yes! Please keep us updated!
  11. I'm not clear on whether you have actually turned off your iPhone and tried charging it.
  12. If i'm not mistaken your iPhone can not be charged when on, and only when off as far as I can recall. Try that and let us know if there is anything different in your case before we carry on problem solving.
  13. It sounds like a mechanical click to me, like those mechanical keyboards for gaming
  14. This is what John B had to say about it in earlier posts
  15. Hey ShowerHead, Mine was: When I reset to defaults it was this value: I have only changed to the default them and done a soft reboot and a hard reboot and since then I haven't had any problems.
