Nexolek
    Canada
    Paranormal 75C | Therion BF 75C | Therion 75C | HCigar VT75C | 4 x Mirage 75C | Finder 250C | Epetite
Nexolek's Achievements
  1. Huh, weird. I pasted that right from the pdf. Seems to be a bit of confusion since both documents are from Evolv. Edit: actually it's the same document. I pasted from page 17.
  2. From the 250C manual:
  3. Well, I figured I'd try to help out, so I sent my Finder 250C to Evolv for some testing. So far, of course, it hasn't misbehaved. Here's hoping!
  4. Are you able to get a screenshot of a few puffs in Device Monitor? That might help.
  5. I get what you're saying. As far as I've seen and tested (cause I was also curious), the C based boards don't auto-adjust cold ohms. It'd be pretty slick, but it seems that manually measuring is the way to go. I do it fairly often, especially since outside is almost always vastly different than inside round here. I use a specific profile for a given atty cause I switch up all the time. I always keep the ohm lock on with TC coils and do a manual measurement when everything is at at a stable "cold" temperature. From there I don't need to touch it and all is well. It works for me at least 🙃
  6. Just installed the test firmware. For science!
  7. Huh, they don't have the chemistry on the wrap and they don't have any markings on the cans either. For me they've been doing great. Probably not so good for high power though according to Mooch.
  8. Huh, guess I'm not going crazy. This happens to me as well (though it's somewhat rare). I use my own theme which is loosely based off of Material-ish Ocean. I don't have anything updating while firing though. In fact I always use stealth mode. I use the same theme on 5 75c devices and I've only had this happen on a 250c. Every now and then it just doesn't fire. Doesn't matter what atty I'm using either. I only use TC though so I'm not sure about wattage. Hopefully a firmware update will fix it?
  9. Freemax makes some stainless steel mesh coils, which will work in either wattage or TC. That'd be a good place to start. Haven't tried them myself but they're rather nice from what I've read around the internets.
  10. I've been using IJoys in my Mirages and they've been good so far. That and they're the only decent 21700s I can find locally (I try to support local shops when I can). Once Samsung 40Ts show up here I'm sure I'll make the switch. If you like high power Samsung 30Ts are rather popular. Best? Who knows. Depends more on how you'll be using it. I'm a lower powered vapor so I tend to favour battery life over 404828 amp* capable batteries. * That does not exist.
  11. Think you hit the jackpot there retird. Loxias, how'd it go?
  12. This is from my Mirage: The first is with replay (warmth at 1) and the second is back to TC. Quality of the vape stayed the same even though replay used a bit less power in that case. I'm perplexed 🤔
  13. Probably best to either talk to the manufacturer of the mod or submit a ticket to Evolv. What mod is it? Does it happen with any atty?
  14. Wow! I've had one for ~4 months and other than discolouring of the stickers and a minimal bit of paint wearing off it's looking pretty good. Love how they sent the not so C bit 😆
