Gm111
    Wales
    DIY woodie, DIY mini, Efusion, Vapecige & Reuleaux
Gm111's Achievements
Senior Member
Senior Member (3/3)
  1. Just press continue anyway, I'm sure im using mine on an old xp pc (use a Mac normally just use windows for escribe). Although I can't remember getting that message..
  2. I thought it might as my first did but my battery went bad and I couldn't get rid of the message even with a new battery.. Still try a few others and see if you get the message.. If you do then take the batteries out and try a hard reboot also if you have a multimeter test the batteries are all in balance..
  3. Here you go http://helpdesk.evolvapor.com/index.php?a=add
  4. Try another usb cable as this could be the problem.. Did escribe recognise the device when you plugged it in?
  5. Can't really help you as to wether you could use it as a mech aswell and don't think many people could, I don't think having an off switch for the board is a good idea, The board is designed to go to sleep after about an hour too keep it accurate..someone should be here to chip in soon.. Maybe it would be better to see if Evolv could add in a mech mode like the evic mini and a few others do?
  6. Ouch sounds like you had a short somewhere, if this a custom mod or have you bought it somewhere? do you by any chance have the mod resistance set as this could be the reason it's not going into tc?
  7. I think if all the settings wernt there from the factory they would all be standard from evolv.. So battery should be 9.99wh, what is the mod resistance set too may I ask? Yes you can use it off tc but need the right csv file for the curve, go on steam engine on wire wizard leave everything as it is but change wire type to ti grade 1 and the where the graph is change to dna200 then download that file.. On the custom profiles on escribe upload that file to one of them.. Lock your watts on device and scroll though to your to profile.. Them change your preheat, watts and temp according to the way you like it, I do this using device moniter so I can see exactly what is happening but that is upto you..
  8. What are the settings you've heard of that come wrong? Also what coils are you using, ni200?
  9. Lewis didn't start this thread, he's just putting his input in
  10. Are your coils touching? If so space them out.. And is the atomiser analyser showing your ohms stable?
  11. According to the graph in the specs 3ohms is the highest..
  12. That's odd, should have worked fine using the correct usb cable.. I've charged mine using a usb car plug loads in the past..
  13. Any update after 15/09/03 should have ecig stats program with it, check your pc for it.. If you don't have it, update the newest escribe again and when going through the update checks make sure the ecig stats q is ticked to download it.. I think this should do what you want although I havent used it..
  14. I'm sure in one of the escribe updates there's a program that does all ecig stats..
