justchil
Everything posted by justchil
Evolv reference case
justchil replied to Russ ModCrate's topic in Connectors, Components, and Accessories
Dimensions of 950/1300? I know I've seen others ask but I never saw an answer posted. You can fit a maxamps 1850 in nearly the same space as a turnigy 1300-1500. -
I am curious if anyone else notices this.... I ran battery analyzer several times with long cooldowns in between. Every time I run it I get about -1Wh from what the battery is rated for (Maxamps 1850). I will see 100% charge when the pack voltage is 12.3-4. I changed the WH using the calculator and the battery % goes down to ~94% which seems right. I will run analyzer again... this specific mod has around 1months use on it.
Max Charging Amperage? Which Wall Adapter to Use?
justchil replied to HugeEgo's topic in Batteries and Charging
One note I've noticed. If you use a "Charge/Power only" usb cable on a PC you will charge at 1amp. Typically with a data cable you charge at 500ma (1/2amp). -
Feature request: New set of "Fields" in screen tab.
justchil replied to justchil's topic in EScribe, Software and Firmware
I know there is a thread about showing TEMP instead of WATTAGE while in temp mode (or at least an option to). In addition (or alone) I would LOVE to see a third set of "fields" -- temp mode fields. These are generally my default settings. When I use a temp control atty I manually go in and change the default fields. Wouldn't it be great if there were default fields for when the device is using temp control? Make sense? Edit: Temp Field 1: Wattage Temp Field 2: Temp Temp Field 3: Last Temp Assuming the Temp/Watt swap happens that is being requested by many. -
I would LOVE to see this. I don't use temp control very often. So I have to remove it from my "fields" otherwise I have - - - for temperature. It would be nice if the device is not in temp control mode to put the user selected field -- if it is in temp control mode display wattage. Sort of how the RX_Clone is setup.
I have two screens one had a green protection tab the other has a red tab. The cable looks different but I haven't tested to see which is tougher. I am super super careful with screens right now
Place to share Battery Test Results.
justchil replied to mikepetro's topic in Batteries and Charging
I'm also curious which enclosure "Bob" was able to get a MA 2800mAh into I will be posting results tonight. I ran 5x tests per battery type. I did see more mAh firing at a lower wattage with a 2.5v cutoff but not at 100w/2.5v. -
I see that now. Looks like when the sag hits the cutoff it's stopping the fire which is expected. I am testing several batteries... I think all are already on the list but I have multiple of each and I'm doing breaking them in first the proper way etc. Looks like some folks doing tests on 18650's are using 2.5v cutoff. I wonder if that would skew results vs/on lipos? It might be a useful field to add to the list if nothing else. PS: That's an insane block of aluminum Have you checked temps on the resistors? -
Are you guys firing until the soft cutoff hits or what? -
510 99.9 pure copper Mod resistance tools
justchil replied to vegabob's topic in Connectors, Components, and Accessories
Sent an email to you. Very interested in 1-2 of these. Thanks! -
That logo is what I'm after. Vector or high res. Everything on google is rather small.
I'm sure it's posted somewhere but I can't have it. Does anyone have the evolve logo in vector or high res format they wouldn't mind sharing? Thanks!
I don't use temp control much (or at all because it's never been a good vape for me) but I picked up a Smok TFV4 TF-STC2 coil for kicks. I have to hard reboot through escribe to get temp control to work at all. It may just be this coil but at 60w temp set at 420F I don't even reach 200F. I tried everything but the only thing that made it kick into temp mode for me was the hard reboot.
Problems with Lipo 3S first Installation
justchil replied to Morphoys's topic in Batteries and Charging
It happens That's how you learn. I had to keep looking at your setup to be sure it was backwards. -
Test your balance plug with a multimeter. That red wire should be your battery positive. The neg wire is on the opposite side. Why would a company use a red wire for a negative side? Unless if that brand of lipo manufacture doesn't follow standards you have it hooked up backwards. My money is on your balance plug backwards. Does nobody else see it?? -
Looks like you have the balance connector on backwards -
Feature request, setting increments
justchil replied to Havensal's topic in EScribe, Software and Firmware
+1 for feature. I almost created the same thread. Custom increases would be nice... even 1w feature would work for me. -
Right. So maybe instead of saying it's a bug I'll say it's a feature request? The buttons should change with the screen orientation imo.
I never noticed that.... I'm guessing the DNA30/40 models I had were so small it didn't bother me to use it in the "left" orientation. It's just a little thing that nags me. When asked "new or existing coil -- press up or down" I'm always confused.
I've noticed when you switch the screen orientation to 'Right' the up/down buttons remain the same. Maybe I missed an additional setting for this but I wanted to let someone know in case it's not intended to be this way.
