xian40
xian40 last won the day on July 12 2018
xian40 had the most liked content!
Full Name
xian chu
Location
usa
triade
xian40's Achievements
its hard to tell. first mod was a physical trouble, second mod error press up is the firware(sp35). just go back to sp33 on it.
- 23 replies
- error press up
- dna250c
(and 2 more)
Tagged with:
i got error press up too directly after sp35 update and check battery error on a brand new triade dna250c. 3 new battery just for him. its weird.
- 23 replies
- error press up
- dna250c
(and 2 more)
Tagged with:
just lower active time. i set mine a 7 sec.
i dont use csv battery profile. csv dont give you longer battery runtime, it is just related to the battery icon status on the mod screen. play with screen delay and timeout in theme editor, it will help runtime. i get better runtime on 75c than regular 75.
hi there, using the same tank on this new mod, any 3000mah 18650 like samsung 30q, lg hg2 or sony vtc6 will fit perfectly. you will obtain approx 650 puffs using 2 bat in parralel.
i dont have this particular mod . but to give you a idea, others dna 75c i have always show me in the mod info screen 4.18v when i know they are fully charged at 4.20v fresh from the external charger and tested on mu multimeter.
Paranormal 75C resistance too high FIX
xian40 replied to ThatGuySwain's topic in DNA 75 Color and 100 Color
you will have to resolder the red or black wire to remove check atomizer error. this is becoming a real joke theses 510 error. no qc at all.- 45 replies
- ohms reading high
- paranormal 75c
(and 2 more)
Tagged with:
mine display correct room temperature only when cold or first time after battery insertion. when i start to vape board and room temp go higher.
Thanks TheSwain, mine was finally a combination of both wire that needed more solder. its now just 0.02 ohm higher in reading the resistance now. dont know if i can call it good now. just have one question. if both black wire and red wire solder is touching under the 510 (because of wire mouvement inside) , what can happen when vaping. are we protected by the board? they are not touching, but just asking. it was the first time that i have to solder 2 wires that what close to eatch other.- 45 replies
- ohms reading high
- paranormal 75c
(and 2 more)
Tagged with:
i have also received nothing in response of this paranormal issue from lost vape. they just dont responded. thanks for sharing this post randy.
the thread lock was probably there to secure more the top of the 510 when unscrewing the atomizer because on the lower base ring ( where the 510 is screwed in ), the negative wire is soldered directly on the ring that can spin if the top of the 510 tight enough. but seriously, the top 3 screws is enough for the negative wire to stay there. i cleaned mine, nothing changed. still read resistance higher than 7 others dna mod. i dont have touched the positive soldering. dont know if this is the culprit or the firmware. dont know what to do now. nice looking expensive mod that just dont work correctly.- 45 replies
- ohms reading high
- paranormal 75c
(and 2 more)
Tagged with:
thanks body.
is there any pictures or video that can show how to do this paranormal ohm reading issue? mine always ask for new atomizer when atomizer is cold, the resistance value is complety off compared to other dna mods i have. thanks
thank you. i will try this. i was thinking it was hex head for the screw. they are so small.
hello to you, what is the hex key size do i need to unscrew the 3 screw on this dna75 c1d2 board? 1 screw is stripped down and i dont know the size i need to order spare screws. i need to open it to fix the same down button issue on mine. thanks xian
