lordmage
Everything posted by lordmage
  1. Perhaps the forum guru's could help me nail down a good tcr and build for this wire. according to the packaging it has a tcr of.00223/f_.004c. i wrapped a couple single coils in the mutation v4 for tested. each one seemed a bit anemic using the tcr in ecribe under special. there is vaper but it is hit and miss. i have 31awg at 3.266 ohms/ft and some 28awg at 1.630ohms/ft. should i be aiming for a specific cold resistance or should i simply try matched duals at this point. each test coil was 3mm using a coil master the first came out to .607 and the second came in at .810
  2. have you not done early access in house beta testing for a company. i have for AVG and a few others.
  3. I thought that was what we were here for, to test the beta releases before they became official?[/QUOTE] i think it would be more accurate to call us field testers not beta testers. they are basicly the same thing. however in a true beta update scheme as soon as coding was done we would be testing it for bugs. evolve is doing the alpha phase in house and the true beta phase. where as we are simply using and providing feedback for future dev`ing
  4. Props to the Op for the app. first use simple to use big plus. using it for the FGCC coils that i am using. of course i had to tweak it for TC. setting the resistance and such. but it is a lovely vape now. much better then using it in power mode
  5. being relatively new to the tc/tl game. i have come to the choice of asking for the option to be added as well. just like we can swap the buttons display and such why not have an option to switch the temp and wattage both on the display and how it would function. ie (5 clicks, hold up/down to get to Temp) as it is default ATM. swap the two then instead of temp it could be wattage. i have tanks that like a certain temp i change that more then i would wattage, when using the best TC curve for it. Example when in wattage mode the device turns TC off, and so naturally i would want Wattage to be what was adjusted with the up and down. when i am using a Tank that i like at 35 watts but change the temp thru the day i would naturally like to have the temp be what is changed by the up and down
  6. i have read in a few places that SS for Tc works best at or above .5 with spaced coils and at least 28AWG using 430 rather than 316. . even large ID but no a lasa i have no SS to test ATM. from my experience with premade STC2 coils i run it. never does it reach a true TC like Ni but my curve climbs slow depending on wattage then goes bonkers if it hits the set point. i sort of gave up on TC with SS wire i use it in tc mode due to better flavor somehow. maybe it is placebo. my go to settings have been posted and tweaked but i float tween my own and dj v4 or v3. but each shows the bonkers issue if it hits the set point if not it is a smooth approach with a punch finish.
  7. [QUOTE=We87][QUOTE=lordmage]i find ss works best with the preheat off. i use "Temperature (degF)","Electrical Resistivity" -58,0.915064 -0,0.95433 68,1 121,1.15 302,1.2 380,1.25 482,1.30 572,1.35 800,1.40 [/quote] I tried this with the 316L SS wire I have and it wouldnt catch temp control, just stood in power mode. Some profiles I have of DJaquith's worked (v3.25 and v7) Is there something additional I need to do in order to get that particular CSV to work? Or am I just doing something wrong? The coil was used in a Taifun GT2 IIRC it is 5 wraps around a 2.5mm which ohmed out on my reader at about 0.9 ohms for what its worth. [/QUOTE] i found what i have to do is play around with the first column a bit to get better performance my coil is a stock premade in the tfv4 which ohms out at .27 cold resistance. "Temperature (degF)","Electrical Resistivity" -58,0.915064 -0,0.95433 68,1 121,1.15 302,1.2 390,1.25 490,1.30 590,1.35 800,1.40 that's what i am currently running i also did the case analyser which could also play a factor. if one off Dj works for you then i would stick with it find your sweet spot and vape on if your not aware the first set of numbers corresponds to the temp the second beats me but it works for me. i usually run at 35-40 watts with no preheat 1,1,0. i also watch the curve as i vape it goes right up and climbs steady to me point then maintains which is when the curve bounces. i have yet to push temp past 400 and it works smooth for me. to much wattage and its all over the place.
  8. or you can copy the numbers and save it to a .csv and load the profile one or the other set.
  9. i find ss works best with the preheat off. i use "Temperature (degF)","Electrical Resistivity" -58,0.915064 -0,0.95433 68,1 121,1.15 302,1.2 380,1.25 482,1.30 572,1.35 800,1.40 which is based a bit off of "DNA200-UD-SS_316L DJaquith V4" Temperature (degF),Electrical Resistivity -58,0.923064 68,1 212,1.15 302,1.2 392,1.24 482,1.28 572,1.312 800,1.398
