Conanthewarrior
Everything posted by Conanthewarrior
Hi everyone. Today I decided to use one of my DNA200's as I have not used them in a while owning so many mods. I downloaded the latest Escribe as the version I had would not open with OS Mojave and connected my DNA200's to make sure they connected. I chose a Hotcig V1 with dual 18650 adapter to use for the day first, connected to Escribe , disconnected and tried to use it. Straight away, it displayed 'check atomiser' when I pressed the fire button- this was before an Atty was in place. It displayed the same thing with some connected that I know to work with other devices. So, I decided to use the Hotcig V2. Same thing. 'Check atomiser' with RDA's and RTAs I know to work. Any idea what is going on? Is it a coincidence that both are showing the same error? I like my mods that use Evolv boards when they work, but by far they have been the most unreliable for me which is a shame as they are also my most expensive mods.
Dont be stupid - this is malware
Conanthewarrior replied to rogue's topic in EScribe, Software and Firmware
In what way is Escribe malicious? I doubt it is, as I have used it since my first DNA200 in the collection. I run on Mac OS, and when I have had some issues and asked on the Mac forums, and was asked to post some things for them to look at, they did ask what Escribe was, and to try deleting it in case it was the cause of my problems. After explaining what it was, they realised it was not at all likely to be causing any of my issues, they just did not know what it was so was suspicious. -
How to remove original Efusion panel to replace Li-Po.
Conanthewarrior replied to Conanthewarrior's topic in DNA 200 and 250
I'm confused, my one is the 1300MAH one, looks like it used the Xt30 connector and not the bigger xt60. It's the original Efusion, not the duo, just thought it might help others who were weary of opening their mod. -
Sorry, here are the photos from start to finish, I can't work out how to link them so they show in the thread, but hope they can help some people- -
EDIT- I did it! I've made a little guide on how to for anyone else- Here is how to do it, with some photos. First turn it on its side, with the screen facing to the right, and the 510 to the top. Unscrew the screws, and then either get something very thin to get between the frame and the panels, or something fin that fits in the screw holes after unscrewing, and gently lever the panel upwards. It will eventually have enough for you to grab. Once you have enough, lift the corners a bit more until you can get some small scissors to cut a little of the panel. The first one snapped itself, but luckily in a straight line. This is how it should look You will open it up to something like this. This is with a new battery, but I had the exact same one as used by lost vapes as I was given it in compensation as the mod took a long time to stock. I didn't know if it would work, as it had been sitting in a draw for around about 2 years at least, as I didn't have a Li-Po charger. You must gently pull apart the yellow connector-the wires pull out with the battery, Be careful not to pull too hard, as the other side of the connector has wires soldered to the board. Then remove the white balance connector which is at the bottom right. This is what it looks like empty, I like the fact the board is protected with a cover, none of my other DNA200's have covers over the boards. Then simply connect the white balance connector, it is very fiddly if you attach the yellow connection first. Then attach the yellow connector. It is a very snug fit- you want the wires from the lipo coming from the far bottom side, DON"T put the Li-Po in with the wires on the balance connection side. Where there is such little space, if you do this you will need to bend the wires at extreme angles, which could cause problems. Lay them at the bottom like in my image above, you will need to press the yellow connector flat against the base of the mod. Success! Went from not charing, and showing battery empty, to working perfectly. I was just about to give up on Evolv this week as every single one of my DNA200's and 75's has had an issue, but I realise a battery is not their fault.
Another DNA200 failure- 5 out of 5.
Thank you @retird. My memory isn't too good (brain damaged), but I recalled the pins in the back of the hotcig sometimes needed moving to get a good connection. I bent them downwards gently. I think this may have happened the other day when I noticed my Li-Po powered hotcig was not working. I swapped the Li-Po for the Li-ion pack to see if it was the battery, and it was. Now I just need to find a new enclosure for the battery. I tried to solder one in before, but messed it up. -
Hi everyone, two days ago my Efusion gave up the ghost, and today I was using my Hotcig DX200 converted to dual 18650's (both of my hotcigs had board replacements from evolv). It was running fine, but then displayed a 'shorted' message, and the battery meter went from full to empty. Now when I attempt to fire, it just displays shorted. I've tried a reset in Escribe, the RDA works on my DNA75 and other mods, so I am unsure what is going on. If it is another failure, I will have to leave Evolv behind which is a shame, as I really like them when they work. I think you can understand my frustrations though and if you had 5 devices fail that used the same boards would feel the same. Any ideas what I can do to fix the mod? I hope it doesn't need sending away as I live in the UK, if it does I will just count my losses and move on. EDIT: I removed the 18650 section, and bent the pins as I remembered these could lose contact. It seems to be working now- for how long I am unsure.
I have tried recovery charging, but it doesn't look like it is working- the Amps are at something like 0.020! Or is this really how long the recovery charge takes? I have 38 mods, so it is likely the batteries have become discharged as mentioned. I try to rotate my mods to use 5-10 each month, and wanted to use my DNA mods this month. I will keep recovery running and hope it works. I have a spare pack for the Efusion, but not for the Hotcig- the batteries are weird in a very small housing.
I havne't tried to tinker with them , the only one I have was a broken DNA75, this just needed the positive wire soldered back in place to the 510, and now works. I will just take some screenshots, my Wismec Relaeux triple 18650 after tinkering is working.I can't get the Efusion or Hotcig V2 and V1to work though, here are the screenshots-the V2 runs on dual 18650's. Whips- I didn';t fire. Two minites.
Hi everyone, I am at the end of my tether with these mods, which I used to love. All four will not charge, and when I try to use them, I get either a check battery, or shorted message. One mod earlier worked for half hour, only to return to doing this. Is there any quick fixes for this? I highly doubt 4 of my mods have failed at exactly the same time, but then again out of 38 mods my Evolv mods have failed the most, requiring board replacements. Is there anything in settings that may be causing this? I have converted one to run on dual 18650's, the other 3 use li=Po's. I hope I can get some help, or I will likely just throw them away. Thanks, Conan.
Mac EScribe Suite Beta Thread
Conanthewarrior replied to James's topic in EScribe, Software and Firmware
I have installed the INTL version instead of US as I am in the UK, I guess this was correct? So far have only tried it with my Efusion DNA200, and it seemed fine. Even updated a service pack to the mod- they might be behind a few due to only using windows for Escribe. Now I can use it on Mac OS it makes things a lot easier for me, and all the other mac using vapers out there. Thank you for this. -
Thank you for your help I will check the grounding screw on both mods, it is strange if there is an issue there on both the Efusion and the Hotcig V2, but it is not beyond possibility. It is hit and miss, sometimes kicking the wire out of TC mode, others doing what you have mentioned. This happened on all of my DNA200's before SP3, then it worked fantastically with SS316L and I was very happy. If this doesn't work, at least I can go back to SP3 if for some reason the update is causing me issues.
Get them repaired, you should be able to, as mentioned part of the board is made by them for the 2A charging so they will be best to go through.
Hi everyone, I have a question regarding SS316L and temp control with the SP5 1.2 update. I could never get SS316L to work well on my DNA200's, until SP3. When I updated to this, I found it to work as well as my DNA75's, and changed it to my main wire type. (EDIT: I should add, it was the included SS 316 profile with the update that I found to work best. I am still using the same one, so am unsure why this is now happening- is it even possible it is the service pack?) I updated two of my DNA200's yesterday after updating Escribe, and now am having the same issues as before SP3 with the mods I updated. The ones still on SP3 are working well. Temp protect is hit immediately, and no vapour is produced, even if I turn up the temp all the way to 300C. (EDIT: Hmm, it does seem to be behaving the same way as I remember- sometimes it fires, and the temp is not reached, others it seems to be registering far too early, and dropping power far too much). Is this a known issue, and if so, can I revert to SP3 on these two mods? I was very happy with the performance before, so would like to get it back working this well
Another issue- battery problems/ not charging.
I only just noticed the mention that you have buggered up a mod with a bad charger- I have changed the USB cable now. I always use a 1.3A supply from the wall to charge when not using Escribe- I prefer to use a supply that is rated slightly more from a good brand (samsung), as I found that the 1A ones seem to get very warm. This isn't just with my DNA200's, everything that charges at 1A, so I use the 1.3A. I know that this is OK as the device will just draw what it needs. How did you damage a device with a bad charger? Sorry to hear that happened too. -
It does actually, fingers crossed it was simply some fluff or similar on the USB male end, and not something like a solder joint or wire, or a failing USB on the actual mod. It is still working as it should be, so it seems this is likely. I actually forgot how much I liked the little hotcig, a very nice size and the 900MAH battery is plenty for my usual vaping style, around 30W with a quick 50W preheat. EDIT: Wow, I only just noticed the puff counter- for the time I have had these mods, I have hardly used them at all! I think my highest puff count is around 9000 on my Wismec or Efusion. -
The mod is fine now I am glad to say The mod does use special removable Li-Po packs- the only problem is you can't seem to get them now. EDIT: Or you can, but they are around £40 on gearbest. The DR200 is the one with the easy to replace Li-Po- I think the V1 and V2 DX200 I have were kind of Beta models that were sold to the public, and the DR200 is the final product. I do have one other Empty housing, from a damaged pack, which I can solder a new pack into when this one needs replacing, and also another pack as I have converted my other Hotcig to use dual 18650's. The numbers for each cell were jumping around very erratically, from 0V up to 5.6V, multiple times a second, which is shown in the graph. It just stopped doing it all of a sudden. I hadn't used the mod properly in a few weeks due to all of the others I have, it is being used today though and is fine. -
Ok well the battery is now stable, and the mod is showing as charging. That was very odd, and I hope it isn't a sign the mod is going to fail soon. I will keep updated. -
Hi everyone. I have another issue with a DNA200, this time the battery reading- it will not charge. I have checked the Li-Po, and it is OK, it is just when connected to the mod it is reading like this, and will not charge. This happened before, and I needed a board replacement. Here is an image of Escribe- it is very erratic. Any ideas what I can do to sort this out? Why am I so unlucky with Evolv , out of 49 mods, 4 out of 5 Evolv mods have now failed, and only one other mod has. -
I see this has been bumped, in the end I kept the V2 hotcig with the Li-Po, and bought the dual 18650 sled/attachment for the V1. The one hotcig made is actually quite good, with the balance connection on the battery attachment side already bridged for 2S use. I just had to change the settings in Escribe and it has worked well since then. I have 4 DNA200's, and with the hotcigs they bought a LOT of frustration. But after refunds, and Hotcig sending me a free V2 for my troubles, each DNA200 cost me just £27.50. I think that was definitely worth my troubles, and I must thank Evolv for their great service in repairing both of the hotcig DNA200 boards. I believe the issues were due to hotcig and not Evolv as my other DNA200's have been perfect.
