Everything posted by Smokin Dave
Going to a backup did the trick. Must've been a wonky theme I installed. All is well with the world again.
Yeah. I saw that. Thanks. I’ll give it a go tomorrow.
Beats the hell out of me. I’ve tried everything from restarting my pc to stop/restart evolve and now I give up. Even trying to install from the evolve suite does no good. Keep getting the same error.
When trying to install a new them an error pops up stating CURVE MUST BE STRICTLY INCREASING. What is this all about?
Oh yeah.For sure the dual coils work in TC.They work great.Just not in replay.They won't register. The single coil no problem in replay.
Apparently dual framed staple ss316L coils that are 6 wrapped 3.mm and are coming in at .06 ohm will not work on replay mode.At least I can't get them to work.A single coil coming in at .17 ohm works great in replay. The duals are on my Aromamizer Plus tank and the single is on my Aromamizer Supreme tank.Both on postless decks. This spooled coil wire from Advanced Vape supply is sooooo good.Easy to wrap and dry burn and no hot spots when dry burning.The flavor is top shelf and cloud production enormous. So if there isn't a fix for this I'll be sticking to single coil for this wire in replay mode.
Mucho Thanks.
75c "Replay" update missing feature ??
Smokin Dave replied to neX's topic in DNA 75 Color and 100 Color
I haven't been able to find it myself.Maybe it's for the 250c only. -
OK, So WHEN is this NEW software for the 75C coming out?
Smokin Dave replied to Joe M.'s topic in DNA 75 Color and 100 Color
I got everything to work using this theme.I'm using the Paranormal 75c with a Aromamizer Supreme and so far it works. EZ-replay (1).ecigtheme -
"replay" rumor mill's already turning
Smokin Dave replied to Podunk Steam's topic in DNA 75 Color and 100 Color
Now that is some exciting news.I want this new replay technology. -
Minimalistic f*ck off theme
Smokin Dave reviewed timvdhoorn's file in DNA 75 Color, 100 Color, 250 Color
Paranormal Battery csv file needed
Smokin Dave replied to Smokin Dave's topic in Manuals, Instructions, and Tutorials
Much thanks, kind sir.I don't know why Escribe kept crashing while trying to apply the analyzer results on my end.I loaded your csv and it appears to be an accurate reading of battery life now. -
It seems both batteries are discharging equally so no trip back for repair is needed.All I need is to get the curve right for the csv. -
I will find out for sure after I drain the current batts and recharge them.If one recharges much more quickly than the other then I do have a problem.It might be why the escribe analyzer did what it did.I don't know for sure.I think it's still under warranty and if so it will make a second trip back for repair. -
After three tries on the batt. analyzer,escribe kept crashing when I would hit accept, the fourth try worked and this is the result.Laughable I know.I loaded it just the same and the Paranormal battery indicator went to zero battery life in about ten minutes.There was plenty of life left of course in the batts so what I need to know from those with a lot more expertise is how should this curve be set to show up on the batt gauge on the Paranormal accurately. -
Right now I'm using LG PVA18650FD1 2000 mAh batteries from Pegasus and when I go to re-charge the batteries one battery will be only 70% drained while the other will be completely drained. I am guessing I need a different csv file to correct this issue.I have run the analyzer to little success.My dumbass doesn't know how to save the results from the analyzer to do a csv file so a little help on that end would be most beneficial and appreciated. Thank you in advance.
Therion BF DNA75C Battery
Smokin Dave replied to tarunprakashsingh's topic in DNA 75 Color and 100 Color
Both my DNA devices do the same thing.Freshly charged and showing 94 to 97 % battery life.I've just learned to live with it. -
LostVape Pharanormal 75C Mod Resistance
Smokin Dave replied to FrankDrebin's topic in DNA 75 Color and 100 Color
I set mine to 0.0014 and not 0.014 even though it always kicks it down to 0.0013.It works and I haven't had a problem since. -
The correct internal resistance for DNA 75c
Smokin Dave posted a topic in DNA 75 Color and 100 Color
After checking out DJLsb vapes review on the Paranormal he states to set the internal resistance to 0.014 which is wrong.It actually is 0.0014 and now my Hcigar VT75 and Paranormal vape perfectly in TC and watts and no more weak battery message after every firing. Try it and I think you will like it.- 1 reply
- 2
The new Paranormal.Same old BS.
Smokin Dave replied to Smokin Dave's topic in DNA 75 Color and 100 Color
Well now.I just received my Paranormal back from repair(thanks Evolv.that was a fast turn around) and now,finally it works as it should have all along.It works great in TC and it vapes and behaves like I like it to do.All of my tanks work on it and now I'm satisfied.Thank you Evolv. -
Yup.That is my suspicion as well.I've already boxed it up and sent back to be repaired.I don't have the time or patience to monkey around with a brand new overly priced mod for it to not work right out of the box.Maybe I should have spent more on the G class.Or really ponied up the bread for one of these........ https://raksasamods.com/ Now those are some mods. Knowing my luck these would be crap right out of the box as well.HA. -
My tanks work fine with my Therion 75 which I had to send in for repairs after a weeks worth of use when I first got it last year.I'll be sending this Paranormal in for repairs as well. Folks,I'm done with Lost Vape. Yeah I know.I jumped the gun on that one.It's Lost Vape that will be getting an ear full.Hell.It's the second LV mod I've had to send back for repairs.I'm a veteran. -
This is what I'm using............ 1 Aromamizer Supreme with staggered fused claptons (28g/32gx2)/32g 3mm/6 wraps 2 Aromamizer Supreme with Triple core fused claptons 28gx3/36g 3mm/6 wraps 3 OBS Engine with the same claptons as # 1 Aromamizer And as I get up this morning all I get is a check atomizer and no atomizer message no matter what tank is screwed in.It won't even fire in watts now.The ohm reading was jumping all over the place before I tried to fire it up and when I did try to fire it the messages appeared. The 510 pins are all the way in on all atomizers.I've tried everything from a hard reboot to soft reboot to changing service packs and on and on bla bla bla. I think I was sent a faulty mod and it looks like I'm going to yell at evolve like I had to do with my Therion when I first got it and had to send it in for repairs.This is BS and I'm really tired of paying top dollar for supposedly great mods and getting crap.
