Everything posted by Smokin Dave
The new Paranormal.Same old BS.
Smokin Dave replied to Smokin Dave's topic in DNA 75 Color and 100 Color
Yup.So far VERY disappointed.It will not fire in ss316L without going right into temp protect no matter what temp it's set at.Fires in watts no problem.I've tried everything I know to do.I am at a loss. -
The Paranormal came in today and no matter what I do it will go into temp protected and not fire.I use ss316L always.I've tried the latest service pak downgraded to earlier service paks and nothing works.Ran the case analyzer and still nothing and I'm using DJlsb's ss316l csv.It fires fine in watts. I'm at a loss. At least the hCigar isn't giving me this headache.
Any feedback on HCigar VT75 Color?
Smokin Dave replied to dl12345's topic in DNA 75 Color and 100 Color
I'm having sticking issues with the up button on my VT75c.That coupled with the fix they sent me for the battery sled I ordered a Paranormal myself.The fix was a couple of round plastic insulators with a center hole punched out to fit inside the positive end of the tube.Now the POS is giving me a weak battery message at only a 15% discharge from a fully charged battery.I'm going to shelve this crap and call it a bad purchase decision.The main reason for buying the hCigar was it had a DNA 75c chip a cool look and would be a good fit for my Aromamizer Plus tank which is 30mm.Looking forward to the Paranormal. -
I tried an 18650 a while back but it was sucking the life out of it so fast that it wouldn't have lasted more than a couple or three hours.So I'll see what newer batts I have with the most mah and see if it is worth going with 18650's.
Yup.I'm getting the same thing.Ni coils,cotton and this workaround tube.Indeed.Really I'm still using the 26650 batts with no real problem with over heating or anything else that raises my ire except a weak battery message. That is annoying.
I've noticed that if I don't have the battery cap completely screwed in I can feel electrical shocks on my finger when I take a draw.My little finger rests on the battery cap when I hold the mod in my hand.I have to make sure I have that cap screwed in tight which makes it a bitch to unscrew when I have to change batteries.I'm thinking that the Lost Vape Paranormal is in my near future and boxing up the Vtc75 and calling it a bad purchase choice.
Dark side of the moon
Smokin Dave commented on danbarnett's file in DNA 75 Color, 100 Color, 250 Color
Well I give up.It stopped for a while but once again I cannot stop the weak battery screen from coming up after each and every hit I take off of this POS.It still hits like a champ and that's all I really want but I've tried everything from exercising the spring loaded battery pin cleaning the threads on the battery door swapping out the themes bla bla bla.Guess it's something I'll have to live with but for the price I paid I shouldn't have too.
Wow. That's pretty messed up.I've had zero problems with anything like that other than a weak battery screen popping up but rectified with a good cleaning of the door threads.Plus I'm using Ijoys and Efest 26650 batts.I'd send it back and say fix this POS. -
I gotta couple of Ijoy's coming right now.They are also on Mooch's list as being reliable and genuine.We'll see how they fare compared to the Efest batts.
Thanks.Yes I've done the alcohol cleaning thing plus I noticed the positive connector is spring loaded and jacked that around a few times.The problem seems to resolved.
The batteries are new going on two weeks old and they are genuine.The current cell voltage reading is 3.8V at 71% charge according to what I see on the battery info screen.I'm going to switch to an 18650 to see what happens.It is performing as I expect it to and I'm not disappointed.
Yeah.Ok.Thanks.The reason I went with the Efest Green 26650 was on Mooch's recommendation.Maybe I'll stick in the 18650 adapter and give that a go.
I'm using Efest 26650 3.7V batteries for my Hcigar VT75C and started getting a weak battery message even though there is 75% or higher battery life remaining.I looked in escribe for the battery type and there are the two usual choices of 18650 Lithium Ion and Lithium Polymer.I've never used 26650's before and was wondering if there is a csv battery profile for the 26650 that I should be using or just ignore the message.Maybe I should run the battery analyzer.I don't know.I need expert advice.Thanks.
I've had the red one for about two weeks and I think it works just fine.I'm experiencing no heating issues with the battery door but I digress that it is a bitch to use the down button when the usb is hooked in plus the buttons can stick but to me not a huge issue.I have a Steamcrave Aromamozer 30mm plus on it and it looks fine.I also swapped out the theme to this one .... which works better than the stock theme. -
Thanks for posting this file.Works well for me.Much better battery life.
Tried this and liked it.This works for me as well.
My favorite rig with either the Gun Metal Aromamizer Surpreme or Stainless Steel.I love the OBS Engine on this Therion as well.
Yes.Thank you.That works.I primarily use ss316L and ni200 wire and now I can use the csv files.Ahhhh.Satisfaction. Thanks again.Go Cubs.
The file I attached opens in Excel.It won't load into escribe as is and I need to know how to convert it to a file I can use.
Hmmm.Yes.I know how to load the files in escribe and set them in the profiles but lets see if this question can help. When I download from Steam Engine it loads the file to Excel.How do I convert from Excel to a file I can use in escribe? DNA200-Clapton-SteamEngine.csv
So this my problem may be elementary for most on here but here I go. I'm having a problem getting csv files because when I download them they go to Microsoft Excel.I have not a clue as how to convert this to a file I can use in escribe. I use Mozilla to download the file but converting from Excel is my problem. Unfortunately this needs to be explained to me like I am five years old.I'm 55 and pretty new to this and my comp skills are sort of lacking. So thanks in advance and for being patient with my dumbness.
Here's where I found it.......... /topic/66731-topic/ click on the recommended link,install and it will give you the latest escribe service pack for all DNA chips.
