Dampmaskin
About Dampmaskin
  • Birthday 10/04/1976
  • Full Name
    Lars Simonsen
    Norway
    DNA 200
Dampmaskin's Achievements
  1. Sorry for the late answer, but I recently wrote a blog post where I try to explain the meaning and the reasoning behind the TC precision number in the Wire Wizard. http://blog.steam-engine.org/2017/04/qa-tc-precision/
  2. Was the 0.6 Ohm figure for a single coil? If so, it makes sense that a dual coil will read close to 0.3 Ohm. In any case, the TCR will be unaffected.
  3. Remember the first version of the Aerotank, the one that looked like this? If you screwed it too tightly on a 510, the center pin would short out inside the base of the tank. I learned that using a mech mod. Fun times.
  4. The DNA 200 draws max 23A from the battery, IIRC.
  5. Tiger wire, is that round wire and ribbon twisted together? Looking at some pictures, I'm just thinking that the ribbon deforms too much and too unpredictably, and I probably can't model it with any accuracy to speak of. There is no TCR value per se in the CSV file. There is a "TCR in vaping range" value in the left hand box in the Wire Wizard, though. If you want to input a single TCR value in EScribe instead of uploading the CSV, you can use that one.
  6. Thanks for the update. I'm eager to try it out. FYI, ATM there are six open pull requests for translations at https://github.com/Evolvapor/EScribeTranslations/pulls I hope you can find the time to have a look at them before the next version comes out.
  7. Are you using US English language and localization settings in Windows, or a different language or country setting? Maybe you could post the settings file here, for others to test?
  8. As far as I know, the 0.4 mm NiFe30 from StealthVape really is NiFe30. Rob got a huge batch of 0.4 mm NiFe30 custom manufactured. I am using it myself, and it works great for me. [quote]so the resistance has nothing to do with the TFR? so i dont even have to input a build? just pick the wire and download the tfr and it should be good?[/quote] As long as you use one single coil material, then yes, the build is irrelevant to the TCR. The build only affects the TCR if you mix two or more different materials in the same coil/build.
  9. I am vaping on the 0.40 mm NiFe30 wire from StealthVape as we speak. In my DNA 200 mod, I use the CSV from the Wire Wizard for this wire. It works for me. The resistance in the calculator was tested by StealthVape and fine tuned accordingly. I do get slightly higher resistance when I build with the wire, but that could be my atomizer. In any case, the resistance does not affect the TFR curve or vice versa.
  10. I am using this wire myself, with the Steam Engine TFR curve of course. It works for me. What kind of problems are you having?
  11. Have you checked out EEVblog's soldering tutorials? They are great, and have lots of tips and tricks for soldering everything from heatsinks to battery cables to surface mounted components.
  12. I can't answer your question, but personally I doubt it will happen. What you could do is to adjust the watts, fire the mod, and read the volts off of the screen. Then you adjust up or down depending on what voltage you want. Repeat until you're where you want to be. Or fire the mod, read the resistance, plug it into some ohm's law calculator together with your prefered voltage, to figure out what the power setting needs to be. What I'll recommend is to simply get used to adjusting the power. You'll become comfortable with it in no time, and I promise you, you won't regret it.
  13. I fully agree. Also, because I adjust the temperature more often than I adjust the power, +1 to the option of switching them around in the interface.
