            Doyle4
                Posts88
Everything posted by Doyle4
	Thanks for 75 and 200 support, working great
	Installed latest, All seems ok so far with my DNA166 something I would like to see in final is it not to look large, if it could look like windows sizes options etc that be great Also, spotted Device monitor, graphs are out of place to corresponding one. Other than that, fantastic Untitled.tiff
	Installed on 10.10.5, installed fine, what i could use without a compatible board attached seemed fine, fingers crossed other boards added later as only have 200/250 and 75 atm.
	Thank you very much James! Tested and working great
	Ahh balls.. I should proof read my comments before posting.. Increments ISNT working on my DNA200, tried with my 250 and that also isnt working, so has to be a bug in the software Thanks, Still very new so its taking me sometime, will get there I hope, so many options, its great!
	I think I may have confused you guys sorry. Increments is working for my DNA200 board sorry, Its this board im having problems with, sorry for the confusion.
	Big difference, I checked the 75C options without a device connected to have a browse around. If you try Theme Designer with a 200 or 250, it brings up the Screen image import options that was under Theme like normal, just a few other options, such as Wattage Increments, but doesn't work, 0.1 always stays. Im sure they will fix it in next update
	I currently dont have the 75C board, but installed the current escribe for the theme designer for when i receive it. Problem im having is the latest version has over written the old version, took me a good few minutes to find the increment settings, As its in theme designer which is intended for the 75C, do you think this is a bug? Theme designer does allow custom screens for my 200 and 250, but as the increments feature has moved to theme designer, i think its not applying it as the board isnt a 75C.
	Booted up another computer with older version of escribe, 0.2 increments uploaded fine, must be a bug in the beta software. Thanks for replying.
	Hello. Im running the latest escribe that supports the 75C as I have been asked to design a Theme for a company. My problem is, I have hooked up my DNA200 and I want the increments to go up by 0.2, I found the setting in Theme Designer, but when I press Apply and upload the settings, it hasnt applied the increment to 0.2, stays 0.1. Any help will be great, Thanks.
	Thanks for reply guys. Tried multiple usb cables, different computers to see if it was the machine its self, still nothing. That is correct, was handed it to see if I could get it working for him, but when i said its dead he said i could I have it as he knows I can use the enclosure, but would like to get it fixed for him before keeping it. From the UK so to send it back costs more to buy than a new DNA250 board to put in, and i have a couple of 200 and 250 boards laying around which i can put inside which is a bonus. Thanks again.
	Hi guys, Got given a Wismec DNA200 mod, plugging via usb nothing happens, screen doesnt come on, escribe doesnt detect board, checked usb status on computer and shows nothing plugged in, this is the same with batteries also. Took whole mod apart and fuse looks fine, bypassed fuse temporally and still nothing. Anyone have any ideas what could be wrong and if it could be saved? Board has no juice present, but was some juice in bottom section of battery sled inside. Thanks.
	If i am not mistaken, batteries are in fact 2500, not 2900mah, although a sticker may be on the batteries stating they are, there not. There is a balance between amps and mah. for batteries with high amps, eg 30amp, the mah will be lower such as 30amp 1500mah, batteries with higher mah such as the 30Q's, they are 3000mah with 30amps, they both cant be high each end. So, i would setup your batteries in escribe as 11.1v with 2500mah, for more accurate batterie measuring, run the analyser, takes about an hour but will be a accurate reading and will also create a battery profile for you at the end. As for needing to drop wattage as batteries drop volts, that is normal, the DNA board is limiting its self to keep you and your batteries safe, if it cant pull the amps and get the amount of volts needed for the wattage, it will drop to what it can. i would suggest in getting better batteries tbh, such as Samsung 25R's or 30Q's Nitecore D4 is a great charger, i use one my self. Charging from the mod its self does take longer as 1amp is being divided by 3, so each battery is getting around 333mah each, on a nightcore D4, they get around 350mah and take around 6hours to fully charge. Hope this helps
	Thanks very much Ed66.
	Tad confused. Looking at the DNA200 data sheet and max input current is 24amps.. but some mods have lipos with 80c.. is the data sheet referring to how many max amps the board will pull or max amps to input? Im building a PSU DNA200, the PSU is 12v 32amp. Thanks
	Thanks guys. I'll look into the resistor option, I think it will be the same as doing an RX200 pass through. Thanks again.
	  Device Monitor for Apple macOS (native)Doyle4 replied to hobbyquaker's topic in EScribe, Software and Firmware Working great on 10.10.5 Great work, look forward for updates. Watching.
	Hello. Made a PSU DNA200 desktop mod. Is it possible to remove the empty battery icon or show it as full? My OCD doesnt like the empty icon showing ha. Thanks
	Thanks very much. I'll do a battery test whilst i do a better search for the battery, at least if search fails i have a rough curve to work from. Link was also a help thanks.
	Hello. Does anyone have a discharge profile for a Turnigy nano-tech 1300mAh 3S? If not, does battery analyser create one after the test? Thanks.
	No as far as im aware, i have the lost vape triade, in the manual it states never to reverse the batteries and take care when removing them. your fuse has most likely blown.
	  Will DNA200 mods EVER have preheat function for wattage mode?Doyle4 replied to joeong's topic in DNA 200 and 250 DustyDizzle, I honestly dont see why not, iv downloaded files from steam for Ni80 and SS316 DNA200 and works fine.
	What batteries are you using?
	V3 White panel version, sanded it down and etched the panels
