dwcraig1
dwcraig1 last won the day on April 22
dwcraig1 had the most liked content!
dwcraig1's Achievements
Senior Member
Senior Member (3/3)
697
  1. Yes enter the resistance value and upload to mod.
  2. I have only one DNA250C mod, resistance on it measures 0.009 ohm. A bit higher than expected but within acceptable range. My Dovpo College DNA60 measures 0.012 ohm Be sure to clean the 510 and shorting plug prior to testing.
  3. What battery % does it show after being fully charged?
  4. Yes I removed the gasket, coils and packing. It wouldn't make any difference though. A 510 to 510 adapter or any old atty no longer wanted will do also. You can use the solder of your choice btw. Also it will require a mini torch or a high wattage iron. I used solder and flux for water pipes simply because I had it.
  5. If you mean what is pictured, it's a Smok dual coil cartomizer.
  6. Yes and yes. Follow directions, first set to zero and upload to device then measure and upload reading to device.
  7. https://downloads.evolvapor.com/SetupEScribe2_SP77_INT_ServicePack.exe At the bottom of page 2 This is SP77
  8. Have you tried using a different cable?
  9. If it is this one it is not powered by an Evolv DNA board so it will not connect to EScribe.
  10. Regarding the DNA25, it is not EScribe capable so it will not connect to a computer. The DNA250C will connect to a computer, Try using a different cable and a recent issue of EScribe. Once connected to EScribe open Device Monitor tab, firmware version will be in the bottom right corner.
  11. It will slowly throttle down to pretty much no power and no burning of the wick.
  12. A couple of things come to mind. Is there possibly another window is hiding under the install window that you must give permission to proceed? Maybe try running it as administrator. Download and install the full package. Uninstalling your current EScribe isn't necessary. https://downloads.evolvapor.com/SetupEScribe2_SP71_1_INT.exe
  13. dwcraig1
    Batt Issue
    The power (amps) isn't getting to the board. Could be weak battery or a bad connection between battery and board (most likely) Using EScribe's Device Monitor with the boxes checked like in my image test yours to see how much of a voltage drop that you get. In my example it is 3.26 volts. If it were to drop to below 2.75 volts (default setting) it would decrease power accordingly. Hover your mouse over your Device Monitor to show levels. Post it here afterwards. My guess is that yours will drop below the set cutoff.
  14. dwcraig1
    Batt Issue
    It could be that the battery isn't tight enough against the battery contacts on the mod, Is the battery wheel bottomed out in it's threads?
